Video I found
Old Feb 23, 2014 | 07:29 PM
Tofan's Avatar
Tofan
Video I found
So after doing some talking with the wife, and us discussing how little problems the 6.7 Powerstroke has had in it's 3+ years of existence, I wanted to find all technical videos on youtube out there. I found this one and like the other comments don't know why it's blowing the oil cap off. Any thoughts?
Old Feb 23, 2014 | 10:34 PM
FishOnOne's Avatar
FishOnOne
The tech reported the air filter was not installed correctly therefore allowing unfiltered air to enter the engine which is probably why the engine is using oil and has major blow by which is demonstrated by the oil fill cap popping off.
Old Feb 24, 2014 | 07:39 AM
EpicCowlick's Avatar
EpicCowlick
Wow, interesting. I just tried this and it doesn't happen on my truck. I did have a sort of similar problem on my first tow back in 2010. I didn't seat the dipstick fully and the pressure popped the dipstick out and blew oil all up under the hood and all over the engine. What a mess. My problem was solved by simply making sure I fully seat the dipstick in it's tube after check oil levels.
Old Feb 24, 2014 | 11:13 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Yup. Needs new rings.
That, and there is probably an issue with the CCV filter.
Old Feb 24, 2014 | 12:25 PM
rtazz17's Avatar
rtazz17
I faintly remember something when I had my 7.3 about the ccv getting clogged and blowing oil out everywhere it could.Turbo,front seal,oil cap etc.But I think that had to do mostly with a mod guys did on the ccv vent and the hose freezing the fluids inside...
Old Feb 24, 2014 | 04:30 PM
BigF350's Avatar
BigF350
FTE Emeritus
Fortunately with our trucks we have a very impressive cyclonic filter setup to extract the crank case oil prior to it being released into the intake that the 7.3 never had.
Although if the oil is cold, it won't filter it out as well.
Old Feb 24, 2014 | 07:42 PM
Jus2shy's Avatar
Jus2shy
Man, that's a bad case of dusting. I feel for the owner. But then that's why I either do the maintenance, or the dealership does the maintenance. JiffyLube and the like scare me.
Old Feb 24, 2014 | 10:02 PM
FishOnOne's Avatar
FishOnOne
Here's a video with the cyclonic oil extractor unit.
Big Red
19
Dec 3, 2011 12:43 PM
f250meangreen
Nov 18, 2005 06:22 PM
chandlerbf
Jul 30, 2004 10:26 AM
64bird
Sep 24, 2003 05:35 PM
reberhardt
Aug 27, 2001 12:19 PM
