Fuel inlet nut wrench size
Old Dec 26, 2013 | 07:23 PM
jeronlines's Avatar
jeronlines
The line is 3/8" and I thought I used a 5/8" to take it off the nut when I took the bowl out to rebuild it. Now, I can't seem to get the full size wrench on and am looking to buy a stubby wrench. It is in a tight spot and I want to make sure I get the right size.
The rail lines are 9/16" and the FPR is a 5/8".
Old Dec 26, 2013 | 09:33 PM
mueckster's Avatar
mueckster
The inlet nut wrench size is 3/4".
Old Dec 28, 2013 | 05:30 PM
jeronlines's Avatar
jeronlines
Thanks, that did the trick.
Now my problem- I don't think the nut is tight against the bolt. It feels like there is a little bit of rubber between the two (the nut and bolt in the fuel bowl). I can tighten the nut and feel it "spring" in and then back a little. Is that the parker sleeve that didn't seat right?
When I put the sleeve on the fuel line and reinserted into the bowl I'm not 100% certain the line went all the way in to the lip to push the sleeve back. In other words, as I tightened the nut it may have been pushing the line and sleeve to fully seated before really engaging the threads.
Is that possible or am I missing something?
Old Dec 28, 2013 | 10:22 PM
mueckster's Avatar
mueckster
Are you saying that the Parker sleeve may have "road up" onto the flared lip of the line, not allowing it to seat properly when tightened? It is possible that this could have happened. You may need to take the nut off and make sure the sleeve is behind the lip. Hold the line against the fitting while starting the nut and tightening it down.
TyBragg
19
Oct 26, 2012 06:26 AM
Sark
Jan 19, 2012 03:50 PM
hansont
Apr 18, 2008 03:57 PM
truckmonger1
Aug 26, 2006 10:10 AM
Hangfire
Garage & Workshop
Jul 25, 2005 11:17 AM
