Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Flair Nut Wrench
Old Jul 17, 2005 | 02:04 PM
Hangfire's Avatar
Hangfire
Flair Nut Wrench
I'm trying to remove my fuel lift pump (F-250, 7.3) and the nut on the line out is stuck. I've tried using a regular open end wrench but not having any luck. I've heard that Craftsman flair nut wrenches spread open, can anyone recommend something that won't break the bank, S-O, Mac, etc...
Old Jul 17, 2005 | 02:45 PM
gbadgley's Avatar
gbadgley
As you said, snap on, mac, even craftsman. One of the tricks is to TIGHTEN the nut slightly before you try to loosen it. Greg
Old Jul 25, 2005 | 07:43 AM
Bart99GT's Avatar
Bart99GT
I was going to tell you to gently heat it a little until I noticed it was a fuel line. That would probably be a bad idea in this case. It will help loosen up a stuck flare fitting most of the time because of the drastically different expansion rate of the metal used in the nut.
Old Jul 25, 2005 | 11:17 AM
kgwld1's Avatar
kgwld1
I have both the snap ons and mac's after using these I tossed the crafstmans as they were just rounding nuts there is a big diffrence.
