4R100 No fluid filling converter or coming out cooler lines.
Old Oct 10, 2013 | 06:26 PM
D.Moses's Avatar
D.Moses
Question 4R100 No fluid filling converter or coming out cooler lines.
I have a 1999, Ford Expedition, Eddy Bauer 5.4 lt Triton.
Well here is my story. purchased it about 6 months ago and it had a little knock, ended up being a cracked flex plate so I replaced it. It drove well for a few hundred miles then one day when I pulled off the freeway it would not continue going. My brother and I jumped out and started pushing it and he got in it as I was pushing it and while in drive he reved up the motor and it started to go but high rpm's and slowly going. Anyways got it home and replaced the torque converter, because you could hear broken pieces in it. Went to fill it and no circulation of the fluid. I put 2 quarts in the converter before I installed it but it wouldn't fill or circulate the fluid. So I went and bought a re-manufactured tranny pump. Dropped it again installed new pump and when I went to fill it same thing. From here I went to pick n pull and pulled a tranny and installed it went to fill it up and same thing not circulating or filling up the converter. So I figure I couldn't of got a transmission with the same problem and that some how it must be electrical. I checked the pcm relays, fuses and diodes and all were fine. Now I'm stumped. Could the transmission module stop fluid from filling the torque converter? Not sure how all the new electrical things work on these newer trannys. If any one can offer a little advice I would greatly appreciate it....
Old Oct 10, 2013 | 07:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It can't possibly be anything electrical. The pump works when the engine is turning. It doesn't matter what the electronics are doing. You can even unplug all the electronics and it will pump and fill the converter just fine.
For some reason the engine is not turning the pump. It could be another bad flex plate, the input shaft, or the torque converter not properly seated in the pump/
Old Oct 10, 2013 | 09:25 PM
D.Moses's Avatar
D.Moses
I am wondering if possibly Oreilly gave me the wrong torque converter.
Old Oct 18, 2013 | 01:48 AM
D.Moses's Avatar
D.Moses
I found out it was the wrong torque converter. Got the right one ant works great now. So weird how the wrong one fit in there great just wasn't locking into the pump. Thank you for your input...
boangenese
Dec 7, 2021 09:54 PM
AK Cold
Aug 3, 2019 07:39 AM
Henryjb
Jun 11, 2007 12:51 PM
fordberg
Mar 18, 2004 12:24 PM
2FordTrucks
May 8, 2003 12:05 AM
