torque converter draining
Old Mar 17, 2004 | 09:19 PM
fordberg's Avatar
fordberg
Can someone tell me the logic behind draining a torque converter. The pump in the tranny is powered by the engine so if the torque converter is empty then the coupling between the engine and pump is broken. So, if you drain the torque converter how does the pump refill it since it has no coupling? I hear many people draining the torque converter with the drain plug. Do I need to pump some back into it afterwards?
Old Mar 17, 2004 | 09:37 PM
Steven@nd's Avatar
Steven@nd
The torque converter has 2 couplings to the transmission - the inside and outside.
The outside is connected to the shell of the converter and turns whenever the engine is running- this runs the pump.
The inside goes to the clutches/bands/planetaries and moves the vehicle via the fluid coupling.
Old Mar 18, 2004 | 12:30 AM
RLKBOB's Avatar
RLKBOB
Draining the TC along with dropping the pan is the only way to get a complete fluid change (other than having it flushed and that's expensive). You just have to make sure when you start it back up you don't try to fill it completely from the start. Start by adding a few qts then crank it over with coil wire removed so it doesn't start. Stop and check fluid level, should be low off the dipstick, add a few more qts and repeat as necessary until the required amount is in(or close to it) then start it and let it warm up and recheck, top off as needed. If you don't do it this way and just start it up and keep adding fluid as needed you will be running the trans with no fluid for a considerable amount of time and will probably cause damage.
Old Mar 18, 2004 | 04:07 AM
coplin's Avatar
coplin
Fords have a drain plug on the TC?? I don't remember the Chevs I've had having one. This would be nice though, get more of the old fluid out at change time.
Old Mar 18, 2004 | 10:09 AM
jimandmandy's Avatar
jimandmandy
My E4OD does, and so does the Torqueflite on the Dodge.
Jim
Old Mar 18, 2004 | 12:15 PM
fordberg's Avatar
fordberg
Oh, now I get it, there are two rotating connections to the tranny from the torque converter. One is the splined connection and the other is the notched connection on the torque converter housing. Thank you for clearing that up.
Old Mar 18, 2004 | 12:16 PM
Casey's Avatar
Casey
Or you could try this: https://www.ford-trucks.com/articles...hangingatf.php
Old Mar 18, 2004 | 12:24 PM
fordberg's Avatar
fordberg
I wonder if running the torque converter without oil even for a few seconds could do damage to the unit. It makes me wonder why Ford no longer installs drain plugs.
Another thing I wonder about is flushing the tranny or sucking the fluid out with a hose. Pushing a tube into the tranny pan could upset the magnet and all of its attached metal grit.
