1979 F150 fuel tank question
Old Oct 7, 2013 | 10:33 PM
powerstroke79's Avatar
powerstroke79
Ok I have a 1979 F150 Custom 4x4 long bed. It has 2 tanks but the side tank does not look like the one's on LMC or Broncograveyard. It had a flatbed when I bought it so I took it off and sold it cause I would rather have a regular bed. The guy that had it before me did some plumbing and put in his own fuel tank selector down below the seat. So how do you know if it was a one or 2 tank truck?
Old Oct 8, 2013 | 12:25 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Is there a switch on the right side of the heat-A/C control panel to switch the tanks?
On factory dual tanks, the tanks are switched electrically. The switch also changes the fuel gauge.
If you have a manual valve then the tanks are aftermarket.
Here's a picture of the right side of the panel minus the switch.
BTW, welcome to FTE. Lots of good people here.
Old Oct 8, 2013 | 04:12 PM
powerstroke79
Ok mine does not have that switch. There is a little toggle switch below the headlight that says Travel Tanks- Aux&Main. That switch works as far as I can tell. The side tank is the only one I can use right now as the rear one has issues,but when the switch is up it shows I have fuel in front tank as it should but push it down and the needle moves down towards empty like it should I would post pic's but I don't see how too.
Old Oct 8, 2013 | 04:16 PM
powerstroke79
BTW my pic is the truck I'm working on.
Old Oct 8, 2013 | 04:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Okay, you have an aftermarket auxiliary tank not the factory dual tanks.
Old Oct 8, 2013 | 04:22 PM
Jklnhyd's Avatar
Jklnhyd
Mike, mine used to have a rear tank, it has 2 fuel doors, and some of the plumbing, does that still mean it is aftermarket? I passed smog cuz it was overlooked, but i need to install a rear tank and all the crap to ensure next years smog....even though i cant afford to fill it anyway.
I saw an AC switch with main/aux switch in a boneyard, maybe shoulda grabbed it...
Old Oct 8, 2013 | 04:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I would say your truck came from the factory with a single rear tank (called the "aft-axle tank") and the mid-ship tank was added by a previous owner.
That's actually quite common. Sometimes two additional tanks are added, one on each side.
Old Oct 8, 2013 | 04:34 PM
powerstroke79
How do you post pic's on here?
Old Oct 8, 2013 | 04:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's one way to post pictures, another is, if you're a paid supporter, you can post pictures as an attachment. To me, that's the easiest way. Two clicks and your done.
https://www.ford-trucks.com/forums/1...l#post13584225
Old Oct 8, 2013 | 04:50 PM
powerstroke79
Thanks Mike I will see what I can do with the pic's.
newandoldford250
30
May 9, 2014 05:54 AM
Serg
Feb 20, 2014 09:17 PM
Mbsmr
Nov 27, 2012 08:55 AM
Sero390
Sep 5, 2006 05:22 AM
MikeGV
Jan 26, 2005 05:47 AM
