Fuel Tank Switch
Old Nov 27, 2012 | 06:28 AM
Mbsmr's Avatar
Mbsmr
4th Gear
Fuel Tank Switch
I have a 1997 F250 with the 7.3 turbo diesel. It has dual tanks on it. For some reason I can no longer switch to the rear tank. I can flip the switch on the dash but it doesn't do anything . The gauge indicates for the front tank and the engine continues to draw from the front tank. Any one had a similar issue and if so, how did you fix it?
Thank you for the help.
Old Nov 27, 2012 | 07:00 AM
fordman67's Avatar
fordman67
Have someone switch it for you while under the truck.i think u will be able to hear it click.if it does not,i would moderately tap with the back of a screw driver and see if it will brake loose.after that you will have to get the wiring diagram and go from there.how long has it been since you switched tanks?
Old Nov 27, 2012 | 08:41 AM
Mbsmr's Avatar
Mbsmr
4th Gear
I usually drain one tank then switch to the other so I don't get a build up of old fuel in one tank. One day it was working and the next day it wasn't.
Old Nov 27, 2012 | 08:55 AM
farmert's Avatar
farmert
Check your in cab fuses, there is one that is in the fuel switch circut.
tmrider
Apr 13, 2019 10:13 PM
retsyr
20
Jan 22, 2017 07:22 PM
newandoldford250
30
May 9, 2014 05:54 AM
Serg
Feb 20, 2014 09:17 PM
MikeGV
Jan 26, 2005 05:47 AM
