E4OD won't shift into any forward gears, but reverse works
Old Oct 3, 2013 | 02:33 PM
Jasonpremo's Avatar
Jasonpremo
Hey guys,
I've been searching around here and Google for a while now but haven't found anyone with my exact same symptoms. I have a 95 F250 with 7.5 and E4OD. I was towing my Jeep and trailer out for the weekend a few months back (its been parked since) and heard some noise coming from the trailer. So at a stop light I put it in park with the engine running for a second, went to put it back into drive and it hasn't gone back into drive since. Reverse works perfectly. Fortunately I was able to back up onto the center divide, unload my Jeep and back the truck onto the trailer and tow home with my buddies Chevy. Anyways, its been dead since. Any ideas on where I can start to look?
None of the forward gears work at all. I'm sort of at a loss here. I'm good with motors, transfer cases, axles, suspension yada yada, but not transmissions. Any help would be greatly appreciated.
Thanks in advance
Old Oct 3, 2013 | 07:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It won't move with the shift lever in 1, 2, or OD? If not, it's toast. Something mechanical broke inside the trans. Don't bother troubleshooting the electronics. It's mechanical.
Old Oct 3, 2013 | 08:30 PM
Jasonpremo's Avatar
Jasonpremo
Nope. Just P, R and N work. D, 1 & 2 don't do anything but raise engine idle. Any ideas on where to trouble shoot from here?
Old Oct 3, 2013 | 09:39 PM
Mark Kovalsky
The easiest way to determine what broke is to pull the trans out and tear it down. Whatever broke is inside the trans and requires a rebuild to fix. What would it help to try and determine exactly what failed first? Now you need to go inside and find everything that is damaged and in need of replacement.
Old Oct 3, 2013 | 10:04 PM
Jasonpremo's Avatar
Jasonpremo
So there's zero way to diagnose anything with it still attached to the vehicle? No chance of it being something simple ie valve body, linkage, solenoid, line pressure etc.? Any idea of what might have crapped out? I'm a sucker for specifics
Thanks
Old Oct 4, 2013 | 08:00 AM
Mark Kovalsky
I did forget one possibility. There are feed bolts that can loosen and you lose pressure to apply the clutches. Drop the pan and remove the valve body. Then find and tighten these: https://www.ford-trucks.com/user_gal...id=253194&.jpg
Old Oct 4, 2013 | 09:41 AM
Jasonpremo's Avatar
Jasonpremo
Ok. Thanks.
What internally would cause this? Clutches failing? Solenoid?
Old Oct 4, 2013 | 09:49 AM
Mark Kovalsky
It can't be a solenoid. It can be a broken sun, a broken shell, a broken shaft, a stripped spline, etc. There are a bunch of things it could be.
Old Oct 4, 2013 | 10:46 AM
Jasonpremo's Avatar
Jasonpremo
Ok. And any of those can go out when shifting from drive, to park and back too drive? Just strikes me as odd as it was working fine up until that exact point
Old Oct 4, 2013 | 11:43 AM
Mark Kovalsky
Yes they can.
Every failure has some exact point where the failure occurred. A crack can begin and spread accross the part. As long as it hasn't gone all the way through the part still functions. At some point that last bit fails and that part is all done.
Old Oct 4, 2013 | 05:10 PM
Jasonpremo's Avatar
Jasonpremo
Alright. Thanks for the input. Looks like I'm making a Craigslist posting today and super duty shopping. Now I have my excuse I've been waiting for lol
Old Oct 4, 2013 | 08:38 PM
PDR60's Avatar
PDR60
I've been looking for a f250. If its a crew I'll seriously consider it. E4od is not too big of a deal to rebuild. I've been through mine twice and a couple of buddies also. Its a very stout transmission if updated and the sonax parts installed.
Old Oct 5, 2013 | 09:59 AM
Jasonpremo's Avatar
Jasonpremo
I'm in San Diego. Probably a bit of a haul for you for an old Ford
Old Nov 20, 2013 | 07:09 PM
Jasonpremo's Avatar
Jasonpremo
Transmission was fubar, planetary gears in the pan etc. Thanks for the help
Dflynn926
15
Jul 31, 2015 02:55 PM
Goober1979
May 8, 2007 07:14 AM
fordfan66
Sep 2, 2006 01:34 PM
ace866286
Dec 18, 2004 02:58 PM
