Axel nut size
Old Jul 29, 2013 | 05:02 PM
newguy399's Avatar
newguy399
Axel nut size
Hey guys I'm about to replace the rear brakes on my 1956 f250. It has a Dana 60 in it and was wondering what size the axel nut is,any tips on taking the drum off?
Thanks
Dan
Old Jul 29, 2013 | 08:28 PM
raytasch's Avatar
raytasch
Believe Nothing
2 9/16" Don't do like some one had done earlier to these nuts.
Old Jul 29, 2013 | 10:29 PM
newguy399's Avatar
newguy399
Thank you so much. I wana do it right and not hack it up.
Is it possible to pull the bearing out and repack it or is it done. I wana replace the oil seal
Old Jul 29, 2013 | 10:36 PM
The Horvaths's Avatar
The Horvaths
At least it looks like it's hexagonal. Albatross ('55 F500) has octagonal nuts. That definitely takes a special socket. I found a good hard octagonal socket on FleeBay.
It will spill a bit, you can minimize that by slightly "tipping" the axle. Change the seals when you close it up. I greased mine, help to keep from running dry before the lube oil makes it to cover the bearings.
Old Jul 30, 2013 | 09:50 AM
newguy399's Avatar
newguy399
Cool man thanks for the 411
powerstroker100
Sep 12, 2010 02:48 PM
Glockem45
Oct 3, 2009 03:40 PM
My Lab Ruger
Sep 28, 2009 08:03 AM
Wrecker
Nov 28, 2004 12:45 AM
bigbean311
Aug 2, 1999 02:07 PM
