Spanner Nut socket size?
Old Sep 17, 2004 | 04:36 PM
Wrecker's Avatar
Wrecker
Anyone know what size socket I need for the Spanner Nut on the Dana 60 rear end on my 79 F250?
Thanks
Old Nov 28, 2004 | 12:45 AM
460Brnc's Avatar
460Brnc
If you mean the big nut that holds the outer bearing in place, it is probably a 2 9/16". I had to get a special *socket" from NAPA (you can also get them from other auto part stores) to get it off so I could pull the hub and drum off to replace the emergency brake cable and wheel brake cylinder.
