Sponsored by: Auxito
1999 F150 Odometer repair/resolder
Old Jul 3, 2013 | 09:27 AM
ronbarbrey's Avatar
ronbarbrey
I recently resoldered my odometer as other posts have detailed. (Thanks for that information) It worked great, but now it continues to go blank and right before it goes blank, it will display ##### symbols. Eventually it will illuminate. Any suggestions, maybe a newer cluster? If I were to get a new cluster, would the miles be updated to original? Thanks
Old Jul 3, 2013 | 10:26 AM
projectSHO89's Avatar
projectSHO89
If you have the cluster replaced by a dealer, they will order the replacement cluster to be pre-programed by their support center with the correct mileage. The mileage is not otherwise re-programmable.
For example, if you replace the cluster with a used one, it cannot be re-programmed "in the field" to the correct mileage. It would also require PATS reprogramming at a dealer or by a locksmith because it won't be able to be started otherwise.
Old Jul 3, 2013 | 11:34 AM
ronbarbrey's Avatar
ronbarbrey
199F150 Odometer
Thanks for your reply. So if I were to buy another cluster, (used from a junk yard or on ebay), it would not start on my truck?
Thanks again.
Old Jul 3, 2013 | 02:25 PM
projectSHO89
I believe that's what I said...
Billinvancouver1
Sep 11, 2023 06:34 PM
h20camper
Jan 17, 2022 02:29 PM
Tech Man
Jun 19, 2020 12:47 PM
Mich6.0
2004 - 2008 F150
Dec 23, 2011 08:40 AM
jeffdoerr
Sep 8, 2008 10:26 PM
