Sponsored by: Real Truck
Instrument cluster
Old Dec 26, 2006 | 10:52 PM
Billinvancouver1's Avatar
Billinvancouver1
Instrument cluster
I have got a new Instrument cluster off ebay same year and model truck I damaged my Cluster removing it to polish the lens.
My big problem is my truck has about 110k and the new Cluster has 25k on it if it was within a few thousand I would not worry but I need to run up the mileage...... How do I do that???
2001 f-350 V10
Old Dec 26, 2006 | 10:55 PM
yamaguy's Avatar
yamaguy
?????????????????????????????????????????????????? ?????????? wow your honest
Old Dec 26, 2006 | 10:59 PM
Hootbro's Avatar
Hootbro
Dealer can reset the correct mileage.
Hootbro
Old Dec 27, 2006 | 12:17 AM
olfordsnstone's Avatar
olfordsnstone
Honesty is always the best policy. Well, almost always. I believe that there are laws prohibiting you from knowingly defrauding the mileage on your odometer. Not sure of the consequences, but I'm sure they could be ugly.
I would do as Hootbro suggests and contact a dealerhip for guidance.
Old Dec 27, 2006 | 07:14 AM
SFeintuch's Avatar
SFeintuch
This may seem stupid but why don't you just change the lens? That is an easy switch and no mileage change.
Old Dec 27, 2006 | 10:16 PM
Billinvancouver1
I was putting a white face on and was trying to pull the needles off and cracked the actual face of the cluster.......... also honesty is not the reason for moving it ahead I bought it at about 92k so I might as well just put in the correct miles 92k or 110k not a big difference value wise.
So basically I can't adjust the miles higher at home! I need to go to the dealer.
Old Dec 27, 2006 | 10:22 PM
Hootbro's Avatar
Hootbro
Originally Posted by Billinvancouver1
......So basically I can't adjust the miles higher at home! I need to go to the dealer.
Back in the day when odometers were mechanically driven, actual "speedometer" shops could do this for you. With electronics driving the current odometers, only the dealers have these tools it seems.
Hootbro
Old Dec 27, 2006 | 10:29 PM
redford's Avatar
redford
FTE Leadership Emeritus
You might want to call the licensing agency where you live and discuss this dilema with them prior to spending money at the dealer. Usually, if you document the odometer change you're covered.
Old Sep 11, 2023 | 06:24 PM
Dyke4558!'s Avatar
Dyke4558!
1st Gear
Smile
Forscan app will let you raise mileage but not reduce it. Its a great app for Ford, but you need the 6.99 pay version and OBDI link.
Works great has a lot of advanced functions.
Old Sep 11, 2023 | 06:34 PM
Hootbro's Avatar
Hootbro
Thanks for dragging me back into a 17 year old dead thread.
