Sponsored by: Auxito
WHERE TO BUY STARTER BENDIX?
Old Dec 5, 2012 | 08:17 PM
carlos1212's Avatar
carlos1212
hey guys I'm replacing my flywheel and starter on my 2000 5.4 due to the known grinding problem.
anyways, I was trying to save a few bucks by just replacing the Bendix.
I've looked and searched everywhere for it with no luck
if anyone knows where to buy one from please point me in the right direction please.
thanks
Carlos
Old Dec 6, 2012 | 07:46 AM
Freightrain's Avatar
Freightrain
You used to be able to get them at your local parts store. I checked Azone and Napa online and neither offer it. Go figure.
Sorry, unless you have a rebuilder in your area(that also does alternators), then likely you will have to replace the whole starter. We have a couple small shops in my area.
Old Dec 6, 2012 | 04:46 PM
RebColonel's Avatar
RebColonel
I don't know where you live but, I just checked in my area.
O'Reillys and Bumper to Bumper list them. if you have time
you should be able to order one online.
They're more expensive than they used to be but, it sure
beats the price of a starter.
Old Dec 6, 2012 | 09:34 PM
carlos1212's Avatar
carlos1212
okay is there another name for bendix? I looked at those websites with no luck.
Old Dec 7, 2012 | 05:15 AM
projectSHO89's Avatar
projectSHO89
It is actually called the "starter solenoid". Just be advised that a lot of parts sources mistakenly call the starter relay a solenoid (which it is not).
"Bendix" is used as a generic term much like the usage of "Xerox" for a photocopier or "Jello" for flavored gelatin.
Old Dec 7, 2012 | 07:42 AM
acogoff's Avatar
acogoff
Starter drive is the correct term, as far as I know. I see Rockauto has a starter for under $70 so that would be your best bet, it looks like.
Old Dec 7, 2012 | 06:40 PM
RebColonel's Avatar
RebColonel
Starter Drive is the correct part name. If you can buy a starter for
$70, that's a great buy. The starter drives run around $35 - $45 depending on the brand.
Old Dec 7, 2012 | 07:13 PM
projectSHO89
Actually, the starter solenoid moves the starter drive to engage the starter motor to the flywheel.
See WSM for specifics.
Old Dec 9, 2012 | 04:10 AM
BFTUFF's Avatar
BFTUFF
Rock Auto has them for your truck: $22.75 listed under "Starter solenoid"
http://www.rockauto.com/catalog/more...365&cc=1362495
Old Dec 9, 2012 | 12:42 PM
Lime1GT's Avatar
Lime1GT
I'd just change the whole starter. If the ring gear is wiped out the starter drive teeth are probably worn and a weak starter solenoid, battery or corroded wiring may have caused the drive to skip wear the ring gear. Only you know if the battery was an issue. Is the work involved changing the ring gear worth installing a partially repaired starter?
Old Dec 9, 2012 | 06:22 PM
carlos1212's Avatar
carlos1212
just to clear up some confusion, i'm not looking for the solenoid.
Im looking for this:
Michael Levy
Feb 25, 2015 06:43 AM
Twotall
26
Sep 24, 2014 06:58 PM
sckootter16
Oct 13, 2008 03:32 PM
96f-150
29
Apr 18, 2008 08:25 PM
fordtruckin
May 6, 2002 07:05 PM
