Fuel filter cap
Old May 10, 2012 | 03:12 PM
Twain's Avatar
Twain
Fuel filter cap
Replacing the fuel filter on this new to me 7.3. I get an aftermarket filter with the filter in the cap. I replace the filter, which was separated from the old cap, hand tighten, crank, and had fuel squirting out in three directions from under the cap. I pull out the cap/filter and compare to the old one. In the threads in the fuel bowl is a fuel line on the right side smack in the middle of the threads. The old cap has two openings in the threads 180* apart from each other, I'm assuming to line one up with the fuel line. I look at the new cap and there are no openings in the threads to match up to this fuel line.
So does the cap need these openings as to have an opening for this fuel line? I don't know if the gasket was message up or the fuel line was blocked by a poorly designed cap??? Early 99 if it makes a didfference.
Old May 10, 2012 | 03:17 PM
CSIPSD's Avatar
CSIPSD
Did you install the new gasket on the filter lid?
The notches in the cap have nothing to do with the fuel flow...
Old May 10, 2012 | 03:38 PM
Brother Les's Avatar
Brother Les
keep your old cap, you may need it one of these days. There are several different types/styles of cap. There are at least 3 different types of 0-rings that I know of (square, beveled, round) and they are sometimes hard to seal. Hand tight will not 'get it' and sometime even tightening it down too tight will cause it to leak. Have the o-ring wet to help the cap slide around it when tightening. there is a happy medim in there somewhere. the opens in the threads should not cause or help anything as far as I know. ???
Old May 10, 2012 | 03:42 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Also, put some oil on the threads because Diesel is not a good lube.
Old May 10, 2012 | 04:05 PM
CSIPSD's Avatar
CSIPSD
All I ever do is remove old filter and install the new. Tighten down and done...
in 1.4 million miles I have had one filter that leaked, and it was installed by Jiffy lube.
Old May 10, 2012 | 04:32 PM
Twain's Avatar
Twain
The gasket must of been squeezed out of position. For a minute I used the new filter and old cap and no leak, but then that combo did not have the screen outside of the element. I put on the new cap on and re-did and all is good now, minus the fuelly smell.
It's a bevelled gasket.
Old May 10, 2012 | 04:41 PM
smithrock's Avatar
smithrock
Just replaced mine 2 days ago. No problems! Make sure the O-rings are in there. tighten to 15ft lbs.
Old May 10, 2012 | 05:46 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Follow this. Its pretty easy, takes only a few minutes. Save your seperate cap, I had to buy one when I went back to an OEM filter.
7.3L PSD - How To: Change Fuel Filter - YouTube
Old May 10, 2012 | 07:18 PM
smithrock's Avatar
smithrock
Yep! Watched your video seeing it was the first time I've changed mine (only owned my truck for a year). Good job Trey!
deejaynetmix
Jun 28, 2022 10:26 PM
00Dave
Nov 1, 2015 09:19 AM
ExPACamper
Mar 15, 2015 11:51 PM
bhmudder11
Jun 15, 2010 11:41 AM
