Need some info, fuel filter cap split
Old Oct 29, 2015 | 05:06 PM
00Dave's Avatar
00Dave
So early this morning I started her up, started smelling raw fuel. Thought that's weird, but waited a little bit. Then the smell got worse so popped the hood. Fuel everywhere and it was shooting out like crazy, from under that plastic powerstroke thing that sits on top. Sooo, get home this pm and get my daughter out to turn it over, thinking it must be a fuel line. Well, she turned the key and whatcha know, the fuel filter cap is broken. Called the dealer and they are $63.00, Clay's is $17.00, holy cow what a difference!!
So the question, has anyone purchased one from an auto parts store and had good luck? I know OEM would be the best, but it takes a few days from Clay and need the truck. Thanks
Old Oct 29, 2015 | 05:29 PM
00Dave's Avatar
00Dave
I found one at oreillys for $16.00. It's Dorman brand. Anyone with experience on this one?
Old Oct 29, 2015 | 05:43 PM
z31freakify's Avatar
z31freakify
You will be alright just make sure they are the same because some some with the screen atached to the filter cap. You should just buy the whole thing(filter with cap)
Old Oct 29, 2015 | 07:20 PM
00Dave's Avatar
00Dave
Thanks for the input, I'm just trying to purchase the cap because I have stock on filters that I purchased already.
Old Nov 1, 2015 | 08:58 AM
00Dave's Avatar
00Dave
Ok, just to follow up and let everyone know, I don't know how, but the cap was split and it wasn't visible without pressuring up the system. When I went to remove the cap, it would break in pieces. I worked gently with a small rubber mallet type hammer and finally worked it loose and off. I replaced it with a Dorman brand cap from a parts house. So far everything is fine with no leaks. So now I have to find a way to clean the fuel from the hood insulation because it was soaked and smells like raw fuel. I pretty much cleaned the engine compartment with degreaser and rinsed with low pressure, then used compressor and air blower to dry as much as possible.
Old Nov 1, 2015 | 09:19 AM
z31freakify
Brake cleaner is your best bet.
deejaynetmix
Jun 28, 2022 10:26 PM
ExPACamper
Mar 15, 2015 11:51 PM
bhmudder11
Jun 15, 2010 11:41 AM
Plat7.3
Mar 9, 2010 10:22 AM
circledwelding
22
Apr 17, 2007 11:10 PM
