E40D OD light flashes only in reverse
Old Feb 8, 2012 | 10:25 PM
zeeman1's Avatar
zeeman1
New to the forum (not to ford) and after reading and learning more than I ever wanted to know about an E40D tranny I have broken down and come to the experts for help. I have a 92 Diesel F350 crew cab and the Tranny OD light flashes at me, but only in reverse, and only under a load. If I back out of the driveway it is fine, but backing up a hill it starts flashing. Once I start moving in drive the light goes away. The tranny was rebuilt about 10,000 miles ago, and it runs beautifully, even in reverse. The only indication of an issue is the light, which goes away once in D. I haven't bought a code reader yet, it seems like such an odd issue I was hoping someone would be able to give me an idea or two to go check. Any ideas would be greatly appreciated.
Old Feb 9, 2012 | 09:13 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
sounds like something funky is going on with the MLPS.
Old Feb 9, 2012 | 10:35 AM
zeeman1's Avatar
zeeman1
Interesting, I'll go check the connections tonight and make sure everything looks good. I think my brother may have another MLPS laying around I could try so at least I could rule that out. Thanks for the idea.
Old Feb 20, 2012 | 09:51 PM
zeeman1's Avatar
zeeman1
Ok, here is an update. I swapped out the Speed sensor in the rear end and the MLPS for ones I had laying around with no change in the symptoms. I did confirm that the OD light will start flashing in Drive as well as reverse, but only when first starting from a stop on a hill, or under a load. It then goes away as soon as you start moving fasser then about 2mph. I got some codes off of it, hope this helps...
67 - PNP or Clutch switch circuit failure
14 - Profile INS Pickup
29 - Open Vehicle Speed Sensor circuit (this was before I swapped out the speed sensor, not sure if it is still there)
Any other ideas? I'm running out of things to try.
Thanks again.
Old Feb 21, 2012 | 04:17 PM
zeeman1's Avatar
zeeman1
no idears?
Old Feb 21, 2012 | 04:37 PM
FORDF250HDXLT
id clear the code,go for a ride and see if code 29 is now gone.
E4OD Transmission diesel RPM sensor is code 14. so make sure your tach sensor is ok. does the tach show proper rpms without any jumping around,for starters?
67 is your MLPS.
since the trans has been rebuilt,it already has the updated MLPS? the new one simply plugged right in,without the need to re-pin correct?
did you clean your solenoid pack plug?
kingair41
May 21, 2012 07:47 PM
denvertruckman
Apr 25, 2009 06:51 PM
alstieg
Nov 24, 2007 01:47 PM
SD714
1997 - 2003 F150
Nov 1, 2003 05:26 PM
jason_blamire
1983 - 2012 Ranger & B-Series
Jul 31, 2003 11:38 AM
