Doors unlock but not lock
Old Feb 3, 2012 | 03:48 AM
jd58980's Avatar
jd58980
This happened yesterday when wife was driving Ex.
She went to lock the doors with the button on drivers door and it would not lock. FOB and keyless pad does not work either.
Now the unlock function works fine.
Any ideas?
Old Feb 3, 2012 | 10:43 AM
dockrocker's Avatar
dockrocker
Door lock actuators, known problem with all Ford Super Duties. Zillions of posts on how to fix.
Old Feb 3, 2012 | 11:53 AM
robert_l_ross's Avatar
robert_l_ross
Not 100% of the time.
If you can hear the actuator trigger when you hit the button, then yes, check the resistor fix for the actuator (search the thread for 'tinfoil fix').
If the actuator isn't moving the lever at all (no sound, can't feel any movement when you rest a finger on the lock lever), then it could be the actuator motor is toast (only spinning one direction) or that the wiring has an issue.
You can test the wiring with a multimeter...if you find the wiring is good, time for a new actuator or actuator motor if you can find just that.
Old Feb 3, 2012 | 12:03 PM
LivingLarge's Avatar
LivingLarge
X2--Jim, first 2 replys to your thread are both good advise.
Hope you learned something from this, that's right, don't let the wife drive the Ex.
Old Feb 3, 2012 | 12:11 PM
jasonodsky's Avatar
jasonodsky
Have her try the key pad to unlock the driver door. Then press #3 and that will unlock all the doors. If #3 works for all the other doors then it is isolated to the driver door actuator and not the key pad. Then follow the advice above.
Every once in a while, my remote does not work, so it could be a blip/co-ininkydink that the both happened at the same time.
Old Feb 4, 2012 | 02:34 PM
jd58980's Avatar
jd58980
Thanks for the suggestions everyone. Went out this morning to diagnose the problem and it started working flawlessly.
Maybe LivingLarge was correct, dont let the wife drive the EX.
NorthCarolinaExpy
Jun 17, 2019 08:02 AM
KillyMcGee
Mar 28, 2018 01:29 PM
97ExplorerEddieBauer
13
Apr 8, 2008 06:09 AM
dedhed
Electrical Systems/Wiring
May 26, 2006 02:45 PM
MikeRizz
Mar 14, 2006 08:31 AM
