power lock problem
Old May 19, 2006 | 09:23 PM
dedhed's Avatar
dedhed
Exclamation power lock problem
96 F350 CC (4 door) Power locks won't unlock. Changed both switches. pass side will lock all doors but neither will unlock. Disconnected all 4 actuators 1 at a time, still no go.
Getting frustrated. 14V at all plugs at actuators. was getting 3-4v on lock side or unlock side and 14 on other, till I disconnected front pass side actuator, now 14V & 0V (must have bad actuator on that one) could they all be bad???
Both rear doors are now connected and they lock no problem, still wont unlock.
Both switches give 14V when pressed to lock or unlock.
Any advice appreciated.
Old May 20, 2006 | 08:44 PM
Franklin2's Avatar
Franklin2
If you get 14v+ and then 14v - for lock and then unlock at the actuator, then the actuator has to be bad.
Old May 25, 2006 | 07:51 PM
dedhed's Avatar
dedhed
Thanks for the wiring diagram Franklin2. It turns out that a wire going to the alarm (inside the boot in the door jamb) had come disconnected from the cheap bullet connector that the alarm installer used. Simple problem, easy fix. All it took was 6-7 hours of diagnosis, and now my arms look like I was playing with a gator (lot of sharps inside doors). Again thanks, without diagram, never would of figured it out.
Old May 26, 2006 | 07:14 AM
subford's Avatar
subford
Your welcome, I thought that the wiring diagram would help that I sent you.
Old May 26, 2006 | 02:05 PM
Franklin2's Avatar
Franklin2
I was wondering about that, but I wasn't going to say anything.
Old May 26, 2006 | 02:45 PM
subford's Avatar
subford
He emailed me with the same question. I sent him the diagram and how to go about troubleshooting it and then I never heard from him again.
