Child Lock engages itself
Old Mar 10, 2010 | 08:39 PM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
An odd problem I've never seen before: I disengage the child lock on one of my rear doors, then close the door. After arriving at our destination, my adult passenger cannot open the door from the inside and I discover the child lock has been engaged. What in the world is going on here? I hate to put a strip of duck tape over it, but is there something making it engage? What is the fix for this embarrassing problem? My Adult passengers are getting a complex! LOL
Old Mar 10, 2010 | 08:46 PM
trsimmons25's Avatar
trsimmons25
Do a search on here regarding this problem, it is more common than you think!
Old Mar 11, 2010 | 05:15 PM
jmessin5's Avatar
jmessin5
I'm getting the same problem. Fortunately, my son is 8 and still uses a booster seat.
Without researching this, I would guess it the door lock actuator. When you lock/unlock the doors, it sounds like it's trying several times to lock/unlock the door.
Old Mar 11, 2010 | 05:29 PM
Jigger2020's Avatar
Jigger2020
are safety items like that covered under some recall or anything? Gerry
Old Mar 13, 2010 | 09:11 AM
ArgoExpedition's Avatar
ArgoExpedition
VERY common problem, there have been many threads addressing this; but to paraphrase, the actuator is activated by several things. The vibration from the vehicle, the vibration from the door shutting, and using the door handles. The problem will not go away by itself.
There are several fixes people have used from glue, to extra screws to force the switch to stay up. I dissasembled the door panel and adjusted the actuating rods until they would stop latching the child lock. It took a couple hours but it worked out great and I can still use the child locks if I want. The screws are a semi permanent making it difficult to use the locks again. Either way you decide will probably be fine.
Good luck.
Old Jun 17, 2019 | 06:09 AM
DaRedNeckKing's Avatar
DaRedNeckKing
Easy Fix!!!
Good luck.
Just Spray some PB Blaster and your Problem will be solved...
Old Jun 17, 2019 | 08:02 AM
alloro's Avatar
alloro
On my 97 Expedition I ended up screwing in a 1/4-20 screw in each one right next to the lever to keep the lever from moving.
joshua6430
Mar 29, 2015 11:02 PM
ztodd377
Dec 12, 2014 01:44 PM
the4by4freek
27
Dec 4, 2012 10:48 PM
wojolsc
Feb 1, 2010 10:40 PM
mtatum
Electrical Systems/Wiring
Jun 2, 2009 12:09 PM
