03 Expedtion OBD Codes P0113 and P2197
Old Jan 9, 2012 | 02:51 PM
BassFish1's Avatar
BassFish1
Last week I was driving down the road and I heard a burst of air from under the hood, pulled over and checked it out, one of the hoses going to my EGR senors split, I fixed the hose and picked a new sensor to be safe.
Now, the truck is not running good, loosing power going up hills and is idling rough. I pulled the codes on it and I am getting p0113 and p2197.
Anyone know what might be going on..?? And how to fix?
<!-- / message -->
Old Jan 9, 2012 | 04:08 PM
alloro's Avatar
alloro
The P0113 means that you probably forgot to plug the connector back into the sensor on the air intake duct. Without the air intake sensor connected, the engine is running a lean mixture by default and causing the P2197 code.
Old Jan 10, 2012 | 08:15 AM
BassFish1's Avatar
BassFish1
Thanks, I checked to make sure and the sensor is plugged in. Could I have knocked a wire loose...?? and would that sensor make the car run that bad.
Old Jan 10, 2012 | 08:45 AM
alloro's Avatar
alloro
Well either way, something is wrong with the air intake sensor or it's wiring. Fixing it should get rid of both codes.
Old Sep 28, 2012 | 08:07 PM
FER2134's Avatar
FER2134
FAULT CODES P0113 AND P1507
MY 2003 EXPEDITION 5.4L AS FART SOLVE THESE CODES TO PASS EMISSIONS CAN HELP ME BY FABOR
cdegruch
Jan 9, 2017 08:44 PM
JTfire13-05
1997 - 2003 F150
Jan 16, 2016 01:46 PM
Cobra Highboy
16
Mar 30, 2009 02:56 PM
Prometheus
Jan 12, 2006 06:56 PM
rook64
Modular V8 (4.6L, 5.4L)
Mar 31, 2003 04:25 PM
