05 F150 Vibration?
Old Sep 5, 2011 | 08:07 PM
vtrip7's Avatar
vtrip7
Unhappy 05 F150 Vibration?
I have an 05 F150 2WD Auto, 4.2 (work truck)...I have owned it since new, no accidents , no towing...used as an "extra car." It now has about 36K on it. About a month ago, I noticed a vibration felt throughout the vehicle. You definitely feel it in your backside and the rear of the truck. I have since purchased new tires, roadforced balanced twice, and also just had the front and rear u joints replaced. (the shop said the center was rather difficult to replace and would require sending the driveshaft out to replace) Nevertheless, the front and rear were replaced. They said the center u joint "seems" fine however.
The tires and wheels are pretty much perfect. The vibration begins around 30 mph or so and is most evident to around 50 mph...both on acceleration AND deceleration. I am wondering if anyone has any ideas as the deceleration component has me confused. I appreciate anyone's input.
Old Sep 13, 2011 | 12:54 PM
Coondawg's Avatar
Coondawg
Drive shaft vibration maybe? I'm not sure about these trucks but I know older vehicles have counterweights on the drive shafts for balancing.
Old Sep 13, 2011 | 01:52 PM
Mr.BrrIce's Avatar
Mr.BrrIce
Hi, you should check the parking brake. There are these jaws at the wheels, that the cable connects to, that gets rusty and gets stuck causing the vibration. At least in my case that was the problem. I just took them out, sanded the rust away and used silvergrease and no more vibration problem after that, until now my rear U-joint got busted but thats another story.
Old Oct 11, 2011 | 07:40 PM
rustranger07's Avatar
rustranger07
You ever find out anything about your problem man?
Old Oct 11, 2011 | 08:10 PM
vtrip7's Avatar
vtrip7
Thumbs down Nothing Yet
As we speak, it is at the shop. Both an independent and the dealer are saying the drive shaft. The independent had the two piece shaft balanced twice, but still vibrated...but much less. Apparently, the shop owner is now looking into why the shaft will not re balance perfectly. All three U joints were also replaced. The carrier bearing, according to everyone, is fine. Only about 37K on the truck. I should know more within a few days.
Old Oct 12, 2011 | 08:52 AM
rustranger07
Ok yea man let us know. Sounds almost exactly what my truck an I'm in a lost for words what it is on mine an running out of money to replace this an that.
Old Oct 16, 2011 | 11:16 PM
dude78's Avatar
dude78
I agree with Mr.BrrIce. Check the E-brakes. They stick on and cause rear end shake. Mostly happens in northern climates because of the road salt. I drive two 2005 F-150's and it happened on both of them.
Old Oct 19, 2011 | 09:38 AM
camarokid91z's Avatar
camarokid91z
Check the e-brake...
Old Oct 22, 2011 | 08:25 AM
pettermax's Avatar
pettermax
ilateapex
19
Aug 7, 2012 12:07 PM
VORTMAX_99
Mar 24, 2009 11:46 AM
MSC
Feb 10, 2006 08:20 PM
Jawbreaker
Jun 25, 2005 06:45 AM
gammer2000
1978 - 1996 Big Bronco
Aug 23, 2001 02:00 PM
