if the 2011s are anything like the 2008s, fog lights will be a plug & play addition...
two lights, wiring harness, w/fog headlight switch
I have a 2006 F-150 I want to add fogs but without the nose guard is there a way and do you think that the truck is already wired I have the fog light symbol on the light switch on the dash. What do you think.
Ford usually tried to make their trucks universal in the factory and then they would outfit them per customers specs. I would not be all that surprised to here that this is true for the f-150s also. Check your light switch. If it pulls out as if to turn on the fog lights, you may have the correct switch. I would check with the dealer to make sure though. Find out if there are two different part numbers and if so, which one do you have. Do a little research here on the net and you may even find a kit to install them. I found mine on eBay. I would doubt that the new f250 is the only kit offered.
Ocastellan, I've moved your post and the one following it to the 2004 - 2008 F-150 forum. You should be able to get a better, more informed response here rather than in the SD forums.
