Sponsored by: Auxito
Fog Lights
Old Dec 23, 2003 | 08:06 AM
GF150's Avatar
GF150
Fog Lights
I want to put some fog lights on my 1999 F150 Lariat. The light controls already have the switch for fog lights, however the truck did not come with them. Does ford make the light kits to fit with my exsiting front bumper, or do I need to replace it. It currently has the original grey bumper.
thanks
GF150
Old Dec 23, 2003 | 09:48 AM
MrBSS's Avatar
MrBSS
Surprising that you have the switch but not the lights. I believe they were standard on the Lariat. Wonder if it was repaired without replacing them.
The Ford accessory foglight kit includes a new valence and switch. I think it costs about $300.
Old Dec 23, 2003 | 09:56 AM
GF150's Avatar
GF150
didn't have the light kit, I don't believe there was any repairs done (2nd owner).
I'll check w/ford in reference to the light kit.
thanks
GF150
Old Dec 23, 2003 | 01:36 PM
PaulC's Avatar
PaulC
You can't determine that your switch is foglight-ready because it pulls out slightly. While that action is required to activate the factory fogs, it also is required as part of the switch disassembly operation, therefore ALL switch ***** have that back-and-forth movement built in.
Old Dec 23, 2003 | 03:15 PM
superrangerman2002's Avatar
superrangerman2002
I 2nd the above.
You may be able to a after market air dam with the fogs already in it.
Old Jan 21, 2004 | 09:29 PM
MJEmerson's Avatar
MJEmerson
hate to bring up such an old thread....but how can I find the wire and tap into the wire for the fog lights on the factory switch....
Old Jan 22, 2004 | 09:52 PM
F2504x4's Avatar
F2504x4
someone here said that they were located by the radiator support core at the bottom ,
Old Jan 22, 2004 | 09:56 PM
MJEmerson's Avatar
MJEmerson
thanks F=250...that is right, but the wires are not hot...as it turns out the switch is mechanically the same but it lacks the internal parts to work. The switch has to be replaced with one that supports fogs (part # SW-5262). I found another forum on here after my post....
Old Feb 16, 2006 | 11:00 PM
brandonhadnot's Avatar
brandonhadnot
help me out here
i have a 1999 f 150 i added foglights/valance and new head light switch.. that is designed for fog lights... i still got no power to the factory wiring.. relays are good and have whats needed... so i dont belive your theory of the switch is true.. what else do i need to do inorder to get fire to thru the wiring to the fog lights....??????
Old Feb 17, 2006 | 12:34 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Does the fog light indicator lamp on the switch light up when you turn the fog lights on? Fuse 27 under the dash is for that.
Fuse 9 under the hood is also for the fog lights.
Old Feb 17, 2006 | 05:08 AM
brandonhadnot
Exclamation what do you mean...
the lights on the panel all light up when the switch is turned on.... how can you tell if it is on... i cant
Old Feb 17, 2006 | 08:30 AM
Racerguy's Avatar
Racerguy
There is a little fog light indicator to the left of the headlight switch ****. With the headlights turned on, and on low beam, and the **** pulled, the indicator should light up.
Old Feb 17, 2006 | 10:41 AM
brandonhadnot
dude that lights upwhen all interior light are on... like dash lights when you turn on your park lights..
cadillacmob
39
Jan 15, 2019 10:00 AM
2006 F-150 FordSter
2004 - 2008 F150
Jun 29, 2012 08:49 AM
barnhill910
2004 - 2008 F150
Aug 21, 2011 03:25 PM
fireftnford
1997 - 2003 F150
Feb 19, 2004 03:06 PM
