Adding foglights?
Old Aug 13, 2011 | 06:10 AM
ocastellan's Avatar
ocastellan
Adding foglights?
Originally Posted by TexasRebel
if the 2011s are anything like the 2008s, fog lights will be a plug & play addition...
two lights, wiring harness, w/fog headlight switch
I have a 2006 F-150 I want to add fogs but without the nose guard is there a way and do you think that the truck is already wired I have the fog light symbol on the light switch on the dash. What do you think.
Old Aug 13, 2011 | 10:18 AM
leadsled56's Avatar
leadsled56
Ford usually tried to make their trucks universal in the factory and then they would outfit them per customers specs. I would not be all that surprised to here that this is true for the f-150s also. Check your light switch. If it pulls out as if to turn on the fog lights, you may have the correct switch. I would check with the dealer to make sure though. Find out if there are two different part numbers and if so, which one do you have. Do a little research here on the net and you may even find a kit to install them. I found mine on eBay. I would doubt that the new f250 is the only kit offered.
Old Aug 13, 2011 | 11:19 AM
powerstroke72's Avatar
powerstroke72
Ocastellan, I've moved your post and the one following it to the 2004 - 2008 F-150 forum. You should be able to get a better, more informed response here rather than in the SD forums.
Old Aug 21, 2011 | 03:56 PM
shorebird's Avatar
shorebird
The truck is wired for the lights.
The harness comes from the factory with the wiring in place.
For some reason yours were removed.
RainStroked
Aug 1, 2011 12:04 PM
Jhonson
Jun 14, 2011 07:08 PM
texex
Feb 18, 2007 04:52 PM
GF150
1997 - 2003 F150
Feb 17, 2006 10:41 AM
ovaltrack
Nov 13, 2004 06:34 PM
