Expedition rear window stuck down
Old Jun 26, 2011 | 11:38 AM
effingpot's Avatar
effingpot
Appreciate any help - bit of a novice when it comes to cars
2004 Expedition Eddie Bauer, located in England.
This morning I pressed the down button for all 4 windows and they went down. When I went to put them up - they all went up except one rear window. I need to get it up before the rain starts and hopefully fix it too!
There is absolutely no sound, nothing when i try to get it back up. I think all the power windows are on the same fuse so it must be to do with this specific one.
I got the door panel off and I'm staring at this lot - no clue what to do!
If anyone can help me a) get it closed and b) work out how to fix it I would be grateful.
Thanks
Mike
Old Jun 26, 2011 | 11:46 AM
Gevans17's Avatar
Gevans17
window stuck down
you can disconnect the window glass from the window regulator mechanism, then raise the glass by hand. Look for 2 or 3 screws/bolts through the bottom of the glass panel that secure it to the regulator.. raise and then prop the window in the up position.
Old Jun 26, 2011 | 11:50 AM
effingpot's Avatar
effingpot
Hi Gevans - does that mean I'd leave the cradle down and just yank the glass out and up? I was hoping to keep it in it's frame and raise the whole lost manually somehow but it's hard to see hot it raises/lowers.
thanks
Mike
Old Jun 26, 2011 | 12:03 PM
Gevans17's Avatar
Gevans17
window regulator repair video
go here for video on how to replace the regulator assembly. you must first separate the glass from the regulator/motor assembly. Before you pull it all out, you might want to put 12 volts straight into the motor to make sure it is not just a switch.
More Information for DORMAN 740171
Old Jun 26, 2011 | 12:15 PM
effingpot's Avatar
effingpot
OK the part that says "start by getting the window in the half way down position" is my prob. It is all the way down and inaccessible.
I like the idea of apply 12V direct to the motor - if anyone can help me with the details of how I do that please do.
Old Jun 26, 2011 | 12:41 PM
Gevans17's Avatar
Gevans17
window stuck
jumper wires from 12v battery posts to red/black on the window motor wiring connector. reverse polarity for up and down function on motor
Old Jun 26, 2011 | 03:34 PM
pdqford's Avatar
pdqford
I'm trying to follow this thread. Let me see if I got this right:
The Right Rear window would not raise from the Driver's Door Master Window Switch?
And it ALSO won't raise from the RR Window Switch (with the DDMWS in the "unlock" position)?
Old Jun 26, 2011 | 03:49 PM
effingpot's Avatar
effingpot
Hi you are correct the window won't raise from either the drivers control or the one on the door.
Rgds
Mike
Old Jun 26, 2011 | 04:25 PM
pdqford's Avatar
pdqford
If you have a DMM, let's check and see if you have voltage going to the RR door window switch.
Seeing as how you have the door striped down, let's disconnect the RR window switch.
Then with the ignition key in the "RUN" position and with the Master Window Switch in the "UNLOCK" position, measure the voltage between the pin where the yellow/light green wire comes into the connector and a good ground.
What voltage do you read?
Old Jun 26, 2011 | 04:42 PM
effingpot's Avatar
effingpot
Hi- well my battery drained so I got a jumpstart and took the car for a spin. On the way back guess what - the window decided to play
So it's closed now and I put everythign back together - it's after 10pm here so done with playing cars for the week ;-)
Weird how it should come back after 6 hours or so of not wanting to work.
New rule - no RR window opening!
cheers
Mike
Old Jun 27, 2011 | 11:11 AM
alloro's Avatar
alloro
Probably a dead spot in the window lift motor, or a loose electrical connection. Driving over a few bumps shook it just enough to make contact and get it working.
cstanley44
31
Feb 28, 2019 08:38 PM
actor76
Feb 19, 2017 11:55 AM
darmento
Aug 2, 2016 03:07 PM
Eric White
Jun 27, 2012 12:47 PM
DanielC
Aerostar
Jan 16, 2011 01:51 AM
