Motor oil-trans oil temps
Old Mar 2, 2011 | 07:26 PM
Hd05's Avatar
Hd05
I just turned a 1000 miles and have not yet towed. I am seeing consistent engine oil temps around 204-208 degrees cruising at 65 on a 70 degree day. The same conditions seem to produce trans oil temps around 175-180 degrees. Seems a bit high for an drive-train that is not being taxed at all. Is this in the ballpark of norm?
Old Mar 2, 2011 | 07:46 PM
jim6090's Avatar
jim6090
ballpark of normal. I am within 5 degrees.
Old Mar 2, 2011 | 07:47 PM
Bill Wolf's Avatar
Bill Wolf
Sounds normal - You will probably see an increase in the trans temp when you tow but oil temp will remain pretty steady at that temp loaded or unloaded.
I've got 20K lbs plus behind mine and cruising at 75 produces 208 to 210 on the oil and 205 to 215 on the trans.
Old Mar 2, 2011 | 07:54 PM
ruschejj's Avatar
ruschejj
I tow all the time at interstate speeds and Mr. Wolf is right on. My oil temp does climb to 215 max but generally resides in the 208 range. Trans stays in the 190's.
Adding weight/load to these engines does not really effect them that much unless you are going to climb a big mountain and keep your foot on the floor.
MPG is the same, when you tow light or heavy, fuel consumption will not change that much. Towing will put you in the 11's, 10's at worst, 14's at best. We fight aerodynamic drag much more than we fight pulling weight.
Old Mar 3, 2011 | 11:56 AM
Sgt93's Avatar
Sgt93
At 75 now tow, I am about 203-205 and get up to 189 or so trans temp. It depends on how she is feeling that day.
Old Mar 3, 2011 | 05:41 PM
sandyc's Avatar
sandyc
I tow 95% of the time, this is what I get. Oil temp: 208-212, trans temp: 188-192. Never seen it over the high side.
Old Mar 3, 2011 | 08:21 PM
kodo's Avatar
kodo
ok I have to ask do you guys idle after towing to get the temps down and if so to what temp? and thank you in advance for your input
whitesdford
Sep 19, 2012 10:54 AM
Jasper 1
6.7L Power Stroke Diesel
19
Sep 11, 2011 08:31 AM
Kert0307
Jan 20, 2011 01:49 PM
johnsjsj
Sep 29, 2007 11:47 PM
GarrettRacing1
Nov 19, 2002 08:05 PM
