Help! ECT vs EOT
Old Oct 11, 2010 | 06:22 PM
jims406rs's Avatar
jims406rs
I originally left the valve off, but today I hooked it back up and left it laying in the valley. I put about 250 miles on it today towing about 2200 lbs. And it stayed at a pretty consistent 20 degree difference with a couple 30 degree spikes. I did not hear the fan at all today. I know there are several variables but when should I expect my fan to come on?
Old Oct 12, 2010 | 11:24 AM
jims406rs's Avatar
jims406rs
Is it possible to have another bad oil cooler? I dont know what to do at this point. Dynamite?....
Old Oct 12, 2010 | 11:33 AM
pnj442's Avatar
pnj442
That certainly is a possibility.
Old Oct 12, 2010 | 11:39 AM
moebdick's Avatar
moebdick
Was the flush done before or after the new oil cooler was installed? I hope this is not the case, but if it was done after, it is possible that the new cooler functioned as an expensive metal coolant filter and trapped all the crap that the VC-9 flush rinsed loose from the coolant passages.
Old Oct 12, 2010 | 11:49 AM
jims406rs's Avatar
jims406rs
it was done after, but it was previously flushed not too long ago when the egr cooler was replaced. when it was flushed this time it was really clean. It was pretty much coming out clear from the start.
Old Oct 12, 2010 | 04:45 PM
jims406rs's Avatar
jims406rs
Back to top....
Old Oct 12, 2010 | 09:16 PM
98SurplusExpy's Avatar
98SurplusExpy
It's possible ... I had one fail after less than 2k miles. The one I have in now is holding up so far.
