Wiring Amp-Research Steps
Old Oct 9, 2010 | 02:45 PM
720Deere's Avatar
720Deere
Does anybody have experience installing these on a 2011? The wiring for the passenger side front door is different than the 2010 and earlier trucks. I've tried everything and can't find the plain white wire that I need for that front door. I've given up for now and just grounded that particular wire. The step won't work for the front door but it works fine for the back door for now.
Old Oct 9, 2010 | 09:07 PM
cnvF250's Avatar
cnvF250
How much did the amps cost you?
Do you know if they work well?
Wish I knew more about wiring, but ....
Old Oct 9, 2010 | 10:53 PM
cirrus365's Avatar
cirrus365
Can you find it at the switch and follow it down?
Old Oct 10, 2010 | 07:36 AM
720Deere's Avatar
720Deere
I tried that yesterday without much luck. It appears that you have to follow it the other direction from the 3 wires that I already tapped up to where the white wire comes into the harness. I will find it, I was just hoping that somebody had an easy answer.
As for the cost, I got a really good deal on them, but they usually seem to be around $1100 shipped. I wanted them several years ago on my 06 but just couldn't bring myself to spend the money. When I ordered the 2011, I didn't order any steps on it and applied that money towards the AMPs.
Old Oct 10, 2010 | 10:01 AM
cnvF250's Avatar
cnvF250
When you get them finished will you post a picture of them open and closed?
I am thinking about having them put on mine.
Old Oct 10, 2010 | 06:20 PM
720Deere's Avatar
720Deere
I will get some pictures tomorrow if I have time before it gets dark. I was really impressed with how you do not see them at all when they are closed. I had seen some pictures of Chevy trucks as I recall that the step was visible when closed.
Overall, I wish I had gotten them years ago on the 06! I still have to install the lights, but everything else works like a charm. The only continuing issue that I have is the parking brake cable. No matter what I do with the relocation bracket provided, I can't quite get it to clear the steps when closed. We installed a set on my brother's truck today and his brake cable had less slack than mine so we were able to make it clear 100%.
Old Oct 10, 2010 | 08:06 PM
sdetweil's Avatar
sdetweil
here is another 2011 with the Amp research steps, nice pics
https://www.ford-trucks.com/forums/9...l-done-up.html
Sam
Old Oct 11, 2010 | 04:44 PM
Bearable's Avatar
Bearable
Just this week I removed the King Ranch Chrome Steps and installed the Amp Steps on my 2011 F250. I've really enjoyed having them!!
The white wire runs out of a flat loom that is behind the kick panel on the passenger side. Once I popped off the kick panel, I had to remove the electrical tape and slide the loom back a little bit to get to it. Unfortunately, it's not under the sill plate like the rest but at least its on that side.
Hope that helps!!
Harry
Old Oct 11, 2010 | 05:23 PM
720Deere's Avatar
720Deere
Thanks Harry! I found it yesterday plus installed a set on another truck. Ironically my biggest problem was there is no flat loom in my truck. What is your build date if you don't mind? I'm thinking there was a running change in the last month.
Old Oct 11, 2010 | 05:40 PM
Bearable's Avatar
Bearable
I'm not sure. I just purchased a little more than a week ago. What's the best way to find out the build date?
My loom wasnt terribly flat..more oval-ish!
Old Oct 11, 2010 | 07:33 PM
720Deere's Avatar
720Deere
Nope not even oval here. Just a few fully round split looms. Best way to find your build date would be an OASIS report, but at least the month is shown on your door jamb sticker.
Old Oct 15, 2010 | 05:50 PM
cnvF250's Avatar
cnvF250
Are the Amp Steps working well for you? Are you happy so far with them? Still waiting for good pictures of them .
Old Oct 16, 2010 | 10:14 AM
720Deere's Avatar
720Deere
The steps work like a charm. I actually got the LED lights installed a few nights ago. They aren't super bright but they light the step up plenty good enough to keep you from missing the step in the dark.
Sorry it took so long to get some pictures, but these days I pretty much leave in the dark and return at night pretty much in the dark. I was able to snap a few pics this morning. Not the best lighting but good enough to give you an idea.
The only problem I have experienced so far is the long driveway at work is asphalt millings with a lot of fines in the mix. Those crazy Michelin tires love to kick that stuff up at any speed including less than 5 mph and it lays up on the front end of the steps. I'm not a big fan of the mudflap look, but I may have to go that route for the sake of the steps and the paint.
Look closely and you can see the LED lights. They are not visible from the side at just about any angle of view.
One thing you will notice as you install these is what a poor job Ford does of getting good paint coverage on the less visible areas. You would think they would develop a more thorough process for trucks that cost $60k+! It's even worse on the two tone trucks. The paint work was much better on my 2006.
JWA
29
Jul 1, 2021 05:44 AM
CUINAK
Sep 27, 2019 10:48 AM
mitchc
33
Jun 23, 2015 09:08 AM
maxwalther
2009 - 2014 F150
Aug 11, 2014 01:17 PM
Matt Wi
Nov 28, 2010 05:13 PM
