Dies under load (new)
Old Oct 31, 2010 | 01:05 PM
  #31
wyckedcombo17's Avatar
wyckedcombo17
So what do I do if the intake manifold port is warped and that's where the vacuum leak is? Is there a better fix?
Old Nov 1, 2010 | 09:15 PM
  #32
wyckedcombo17
**shameless bump**
What's the best fix? Besides a new intake manifold?
Old Nov 1, 2010 | 10:31 PM
  #33
fmc400's Avatar
fmc400
MSEE
What do you mean by warped? If it's physically misshapen, it will need to be replaced, unless a machine shop can mill it flat and have it still seat properly. I guess it depends on how bad it is. I'd be curious why it's warped in the first place; that's odd.
Old Nov 2, 2010 | 06:42 AM
  #34
wyckedcombo17
I think its because someone forgot to disconnect it from the choke when they were taking off the carb and just gave it a good yank.
I'll put a picture up of what I'm talking about later today
Old Nov 2, 2010 | 05:48 PM
  #35
wyckedcombo17
^^ that's the piece I'm talking about (with the 2 lines coming out of it) One line goes to the thermostatic choke pull off and the other goes to the air cleaner I believe.
I can't get to that back bolt which is the place it's leaking I think. I already accidently broke off the line to the choke and jerryfabbed that fix (aluminum tape and vacuum line )
Old Nov 4, 2010 | 05:32 PM
  #36
wyckedcombo17
BUMP
Should that plate have a gasket underneath it?
I have a vacuum leak there that I would like to fix so I can tune my carb.
Old Nov 4, 2010 | 11:49 PM
  #37
fmc400's Avatar
fmc400
MSEE
That's the choke stove - I'm not sure if there should be a gasket there; that's an interesting question. I've never removed the plate. To fix the broken heat riser, you'll need to remove the plate anyway, so you'll be able to find out then. You'll need to get at the bolt one way or another. You can fix the tube by bending and flaring a new one yourself out of brake line, or using a replacement kit. I'm not sure what this has to do with the intake manifold being warped though.
Mutt1984
13
Jul 30, 2015 06:15 AM
PARATROOPER82
21
Mar 26, 2015 05:56 PM
JohnBOV43159
53
Feb 7, 2014 11:11 AM
haligen
16
Aug 9, 2010 09:20 PM
slow64
Jan 21, 2008 10:55 AM
