91 F150 Speedometer
Old Feb 23, 2003 | 09:44 AM
dbrown13's Avatar
dbrown13
91 F150 Speedometer
When cold reads 15-20 MPH high. Truck has 180,000+ miles on original 300/six 5spd. Thinking maybe gummed up speedometer head.
Old Feb 23, 2003 | 12:17 PM
steve83's Avatar
steve83
91 F150 Speedometer
Does that mean it reads 15-20mph when you're stopped (i.e., going 0 mph)?
Old Feb 23, 2003 | 12:53 PM
dbrown13's Avatar
dbrown13
91 F150 Speedometer
GPS indicates 60mph, speedometer indicates 75-80
Old Feb 23, 2003 | 08:57 PM
steve83's Avatar
steve83
91 F150 Speedometer
So it's reading 25% high. What's your original tire size and current size? Are the gears the original ratio? Has the trans/t-case ever been changed/repaired/modified?
The speedo uses spinning magnets to push the needle against a spring - the faster the cable spins, the more it's able to compress the spring and push the needle to a higher number. Gumming it up would show a lower number than it should.
Old Feb 24, 2003 | 02:21 PM
dbrown13's Avatar
dbrown13
91 F150 Speedometer
Runnin BFG 255/70/15's which in my estimation is close to the same diameter as 235/75/15's which are the stock tires. It just started this a couple of weeks back (no mods)
Old Feb 24, 2003 | 05:15 PM
steve83's Avatar
steve83
91 F150 Speedometer
I dunno - maybe there IS something in there between the spinning parts & the needle, like a spider web or a flake of rust. Pull the speedo and take it apart. If your GPS can run off the truck power, you can use it as a temporary speedo until you fix/replace yours.
Grosjo
May 31, 2015 07:16 PM
Stevenbowman23
Mar 23, 2015 12:12 AM
smokeywagon
Sep 4, 2014 09:20 PM
JacobRM
19
Jun 3, 2014 06:35 PM
howardsamycia
Mar 1, 2014 12:20 PM
