speedometer malfunction
Old Sep 3, 2014 | 04:03 PM
smokeywagon's Avatar
smokeywagon
My speedometer is bouncing around and I'm shifting all wierd
Old Sep 3, 2014 | 07:20 PM
Wildman25's Avatar
Wildman25
The year of your van would help
If it a '92+ and your having shifting problems, the speed sensor in the rear axle is the problem, this will also effect your ABS brakes.
About a $22 part and easy enough to replace.
Old Sep 3, 2014 | 07:30 PM
smokeywagon
Its a 2000 the speedometer jumps around the speed I'm actually going
Old Sep 3, 2014 | 09:11 PM
Wildman25's Avatar
Wildman25
Replace the speed sensor, should solve your problem.
Old Sep 4, 2014 | 05:48 AM
JWA's Avatar
JWA
Agreed the Center Differential VSS could affect the speedo but that should potentially trigger the ABS MIL light too---right? Mine had accumulated too much debris and a simple cleaning cleared that MIL code.
The shifting issue could also be related to a failing or failed speedo portion of the whole cluster.
Old Sep 4, 2014 | 09:20 PM
baddad457's Avatar
baddad457
Could also be the PSOM in the gauge cluster went out. That's what happened in my old 95. Wasn't the speed sensor in the rearend.
MBDiagMan
Large Truck
Feb 6, 2016 07:35 AM
ErrorS
1978 - 1996 Big Bronco
May 13, 2011 08:51 PM
technomon
Nov 17, 2007 12:51 AM
toolebox1
Oct 26, 2006 10:15 AM
JICASE
Jan 6, 2005 08:54 PM
