timing belt tool
Old Oct 5, 2010 | 05:25 PM
dubbz's Avatar
dubbz
timing belt tool
This weekend I'm changing the timing belt on my 98 Mazda B2500 2.5. Everything I read says I need to have a tensioner tool. (49 UN01 067). Can I get away with just using a pry bar? I did buy the kit which comes with the pulley bearing.
Old Oct 5, 2010 | 07:10 PM
g_k50's Avatar
g_k50
What part of the engine do you want to pry against? and might break in the process? Then you have to tighten the adjusting bolt while holding the tensioner against spring pressure to the furtherest posititon clockwise.
Maybe you can rent the tool?
Old Oct 6, 2010 | 08:10 AM
dubbz's Avatar
dubbz
I see your point. I'll call around and see if someone rents it. Thanks
Old Oct 6, 2010 | 10:21 PM
wtroger's Avatar
wtroger
I have used a pry bar for years. I pry it back using the big bolt that holds the spring for the tensioner as a lever point. Then tighten the bolt down until I am ready to tension the new belt
Old Oct 6, 2010 | 11:47 PM
g_k50's Avatar
g_k50
How do you tension the new belt?
Old Oct 7, 2010 | 09:25 AM
donaldm's Avatar
donaldm
thats what the spring is for, it will set the tension
Old Oct 7, 2010 | 10:16 AM
g_k50's Avatar
g_k50
I was trying to get the procedue for spreading the tension properly across the whole belt. My manual says to put the belt on and allow the tensionor to apply tension but don't tighten the bolt until the engine is cranked over by hand for two revolutions then the bolt is tightened.
Old Oct 7, 2010 | 12:56 PM
wtroger's Avatar
wtroger
First you cannot turn the engine over with tensioner loose it will skip teeth every time. Turn the tensioner loose and tighten the bolt turn engine thru 2 times by hand loosen tensioner and then retighten. Turn through 2 more times and check timing marks to insure they are still in the right place. It they are then you are good to go.
joegeds
Feb 2, 2015 12:47 PM
f350galaxie
Sep 1, 2013 08:24 AM
nickkennett01
Feb 8, 2012 01:33 PM
Sholou
34
Apr 11, 2006 10:45 PM
big catfish
Jan 31, 2006 09:23 PM
