Timing Belt Tool
Old Jan 31, 2006 | 02:46 PM
big catfish's Avatar
big catfish
Timing Belt Tool
Still trying to change the timing belt on my 2.3l 96 Ranger. It looks like I may need the special tension adjusting tool T74P-6245-a.
Has anybody replaced their belt without it?
Or can anyone recommend a place to locate that tool?
Thanks in advance!
Old Jan 31, 2006 | 06:07 PM
el conquistador's Avatar
el conquistador
i did. i loosened the bolt to pop the spring off the stud and used the pry bar to get it back on.
Old Jan 31, 2006 | 09:23 PM
Bart99GT's Avatar
Bart99GT
It merely makes the task take one less step. I just take a prybar and release all the tension by prying the tensioner as far to the passenger's side as it will go, then I tighten the hold down bolt. Install the belt, hold the crank still with an appropriate sized socket and breaker bar, then release the tensioner onto the belt. Rotate the engine by hand (helps to take the plugs out on one side) a few revs, check the timing, then tighten both bolts. With the tool, you can hold the tensioner to the side with the belt in place already. If the timing cover isn't in place, I can swap a timing belt on a Lima in less than 15 minutes now. I left it off on my SVO...but then again I went to the trouble of painting the tensioner and auxillary shaft sprocket and I have a billet aluminium cam sprocket. No sense in covering up all the shiny parts!
FWIW, I've only seen the tool on eBay a couple of times as part of the 2.3L service tools kit. Many times when that tool kit is available the belt tool is missing, no doubt kept by whomever used the kit last. I wouldn't go out of my way to find the tool. If you can't find it in a casual search, then just get a prybar.
ottr1967
Feb 21, 2007 03:26 PM
tennesseeike
Sep 14, 2004 06:04 AM
jonny 5.0
4 Cylinder Engines
Aug 1, 2004 09:20 PM
wolfen
Oct 3, 2003 02:36 PM
fattyarbuckle
Jun 9, 2003 11:02 AM
