EBPV tube fitting for pyrometer?
Old Oct 7, 2010 | 07:36 PM
Highridge's Avatar
Highridge
No cutting and splicing, I had plenty of wire. I did use an adapter though, just a brass female to female I think 1/4" that I had laying around.
Old Oct 7, 2010 | 08:04 PM
bdrummonds's Avatar
bdrummonds
The thermocouple must be in the heat stream to register. If its "just sticking into the manifold" it would make sense that it reads low. On a traditional install your thermocouple would be sticking up at least an inch into the heat stream inside the pipe/ manifold.
Old Oct 7, 2010 | 08:11 PM
Highridge's Avatar
Highridge
That's what I'm thinking. I dont think it's getting enought exhaust gases on the sensor. I'll probably just end up drilling and tapping the manifold and cap the fitting where the ebpv tube was.
Old Oct 9, 2010 | 02:07 PM
Highridge's Avatar
Highridge
Ok, so I drilled and tapped the sensor in front of cylinder #1. Now I get 200-300 on idle and 300-600 around town, which sounds about right. Gonna test it out on the highway later tonight. Thanks guys!
Old Oct 9, 2010 | 02:16 PM
ron's power stroke's Avatar
ron's power stroke
I don't think it will read right under WOT run's...its hard to tell around town...you should have a gauge in the right location to compare too..be interested to hear what you find..that port is where ill have a boost gauge for back PSI readings when the new motor goes in...
LSO1123
Apr 9, 2013 02:57 PM
redman84
Apr 14, 2010 06:39 PM
2New2Fords
13
Sep 21, 2006 08:38 PM
Milwaukee,WI
Jan 12, 2006 10:45 PM
TaosCowboy
17
Nov 2, 2004 03:05 PM
