Chip W/No Gauges?
Old Oct 20, 2010 | 03:05 PM
  #121
Spool&Go's Avatar
Spool&Go
10-4. Well That's what I'll do then. I'll order (not now) pyro and trans temp for the pod, then boost I will mount somehwhere else. You ever seen it on that blank part of the dash? I think that looks pretty sweet. Any other suggestions on where to mount the third when I do this?
Old Oct 20, 2010 | 03:09 PM
  #122
aklim's Avatar
aklim
1 Gauge Column Pod (AT)
Old Oct 20, 2010 | 03:20 PM
  #123
Spool&Go's Avatar
Spool&Go
Hmmmm. Ya I thought about that as an option. But dont they obstruct your vision of your stock gauge cluster? Or is it centered and low enough to not cover much. I wouldnt mind if it covered up my trip meter and a little bit of the odometer. As long as it doesn't obstruct seeing the rest.
What about in this pic where the 4x4 switch is at? Because that is blank on mine. I have the E99, so there's no auto locking hubs.
Old Oct 20, 2010 | 04:07 PM
  #124
cj45lc's Avatar
cj45lc
Thanks man. Another buddy is hooking me up with a double gauge pillar - pod too. So that is a good start for the gauges.
Yea I know I just got done putting in the box, didn't really fit good but I taped the snoot out of it. You can get the trans gauge from them boys I told you about up there by you, that's where I got mine $45 free shipping. How much fuel you think you'll burn up this evening haha
Old Oct 20, 2010 | 04:19 PM
  #125
Vinny Mastrodomenico's Avatar
You could always order the F650 dash from Clay. Here is a picture with volt meters, but you can add the trans temp there.
https://www.ford-trucks.com/forums/9...d-my-dash.html
Old Oct 20, 2010 | 04:42 PM
  #126
Spool&Go's Avatar
Spool&Go
Right on! You da man.
And I will definitely look into those guys. They have autometer cobalts? I am thinking those are the ones I wanna run.
Although I cant see the pic on that link, I have seen the F650 dash before. I dont think that I am going to get that radical. Plus, I like the pillar pods. Thanks for the link though!
Old Oct 20, 2010 | 04:43 PM
  #127
Spool&Go's Avatar
Spool&Go
Oh ya.
I'm sure I will burn through a fair share of fuel tonight. When testing it out I swear I could se the needle dropping.
Old Oct 20, 2010 | 05:20 PM
  #128
tdpower's Avatar
tdpower
That's were I mounted my boost gauge. Only problem in when it's in drive you can't see the very top of the gauge. I should of moved the hole down just a little. Here is a pic:
Old Oct 20, 2010 | 11:10 PM
  #129
Spool&Go's Avatar
Spool&Go
That is sick! I like it. And how much of it does it really cover up? Enough to really reduce the ease of reading it? Because I would center it just like you did. If it wasn't perfect like that it would drive me nuts. Especially if I purposely offset it then someone pointed it out. Was it easy to install? I'm not too scared of cutting holes in my dash. I got pretty good at it from mounting switches, but they weren't quite that big.
PS: WOA! That is weird. I just noticed something. I have the exact same trailer brake deal in the exact same spot on my truck. Wait. That didn't come stock did it? I would feel stupid if it did
Old Oct 20, 2010 | 11:32 PM
  #130
tdpower's Avatar
tdpower
No the brake did not come stock. It was that way when I bought it.
If I hold the shifter up (due to a little slop) , I can see the whole gauge.
I used a 2 inch hole drill (for wood or plastic). I think I needed a 2 1/16 because I had to file some off to make the gauge go in.
Did you get the new programmer?
Old Oct 20, 2010 | 11:46 PM
  #131
Spool&Go's Avatar
Spool&Go
Ok. So If mine doesn't have any slop (Which it probably does) then I will be able to see it fully? I'm sure it depends on how you sit as well, and height.
Yes! I did get the programmer. It is a crazy difference. I really like it. I am done testing it out if you know what I mean. Now I am going to drive like normal . . . for the most part. But even driving around not even getting into it, I can still really feel the difference. I like it a lot. I basically feel no turbo lag at all. With the wicked wheel and that it is amazing the kind of throttle response I have. I am going to stick with it until next year when I can afford to get custom tunes. Heck, I got a good enough deal on it to make my money back when I decide to sell it. Need gauges though as you can tell. I should wait to buy them but who knows, maybe I can slowly put a little away here and there to buy them sooner than later.
Old Oct 20, 2010 | 11:57 PM
  #132
tdpower's Avatar
tdpower
All I can really tell you is my experience with the gauge fitting as I said above.
Glad to hear you are enjoying the new tunes. Just keep it in a low setting until you at least get the pyro. Sounds like you got a good deal...congratulations.
Old Oct 21, 2010 | 12:04 AM
  #133
Spool&Go's Avatar
Spool&Go
Thanks but. See the thing is that there is only Performance, Tow, and Econ. I hear that if you dont haul **** in the perf tune, you will get better mileage and I also hear not to put it in tow unless you are actually towing. So I am thinking I will just keep it in perf and be super careful before i get gauges like you said.
Old Oct 21, 2010 | 12:18 AM
  #134
tdpower's Avatar
tdpower
Tow should be the lowest setting I think on your set-up. That should give you a grin on your face. I did w/o gauges for quite a while but that is a chance you take. I wouldn't keep it in the highest tune you have w/o gauges.
Old Oct 21, 2010 | 09:52 AM
  #135
Spool&Go's Avatar
Spool&Go
Hey is there a big difference between mechanical and full sweep electric gauges? I want the autometer cobalts but the price difference of the mechs tothe elects is like night and day!
