Chip W/No Gauges?
Old Oct 4, 2010 | 04:36 PM
  #31
Spool&Go's Avatar
Spool&Go
Sweet. Thanks for the link. And youre display pic is awesome hahaha.
Old Oct 4, 2010 | 04:53 PM
  #32
spdmpo's Avatar
spdmpo
Originally Posted by Philip Berardi
idk man i would save your coinage on a dp tunner with customs tunes and everythign once your work picks back up. get some solid gauges and stare at how pretty they are until you can get your chip and get it all the tunes you wnant at once. thats what i did. one more reason to wait till spring to get your tunner is the snow and everything will be a damper on your fun factor with the chip...also the cold weather, i ususally let my truck warm up in stock before i go play. thats if youget cold weather where you are(forgot to check sig)
just my .02 man, i know how hard it can be reading all the reactions on here. i just got singles and a chip reburn and im still smiling.
Philip has you covered and echoes what I'd say. Wait until you can get what you want, whatever you spend now will just prolong the time until you can get some good tunes. You don't have to spend a ton of money on gauges either. There are other alternatives to the expensive, but nice, Isspros.
You got some advice in your other thread and this thread on having Jody send you a computer flashed with one his programs, that's what you should have done since you were replacing a PCM anyway. But if you can't wait and can't stand it, then take the advice of others and just have Jody put a tune on your computer and call it good for a while. Just don't lay in to it for a long period of time without a pyro.
Old Oct 4, 2010 | 04:56 PM
  #33
Spool&Go's Avatar
Spool&Go
True True. Ya I dont think I'll go with a chip for now unless I can get one for a screamin deal. I'll most likely end up paying around $300 for gauges and go from there. If I cant afford the tuner after that then I'll just have to wait. Hopefully only until my tax return ha. Thanks for the info.
Old Oct 4, 2010 | 06:13 PM
  #34
cj45lc's Avatar
cj45lc
Good deal Bryce, I think you'll be better off in the long run. I know you young bucks don't like hearing about the long run, haha
Old Oct 4, 2010 | 06:35 PM
  #35
big poppa's Avatar
big poppa
Thanks for the Link! I called the guy. He says that they are autometer z-series (Black background, White numbers, Red pointer). He said that the boost gauge doesn't work well. He said that it is reading 14psi after he put on new up pipes and there is not a leak anywhere to be found. Kind of curious if it is actually the gauge that is messed up. Autometers shouldnt go bad like that. I am first in line for them. I am sending him my email and he will be sending me pictures. He thought about throwing his buddies boost gauge into his truck to see if it is the gauge or if there is actually a leak somewhere. He said $200 + shipping for the pod, pyro, and trans gauges. He also said that he could order up the boost gauge for me and then charge me 250 + shipping for the whole thing but I can order it up. What do you guys think?!
Glad to help Bryce. You can't beat a deal like that with a stick, the fella is making it real nice for yaa. You can get a can of paint from Clay for your pillar to color match your interior. Depending on the future mods of your truck and finances, you can always add additional tunes later if you pick a switch on the fly PMC inserted chip. The guys look like they got you on the right path with tune options, good luck.
Old Oct 4, 2010 | 10:01 PM
  #36
frdf250's Avatar
frdf250
Mike - good to see you, gotta get my bellowed upipes in and then well go crusin to let you test out the stage ones soon!....sorry for the temp highjack!
Bryce - I will keep my eyes pealed for you, i know how your itchin and trust me, its soooo worth the wait. dont waste your money on an sct or anything like that. i bought a hyperpac before i know of this site. all the bells and whistles. full touch screen did everythign you coudl image......i cant even describe to you how diferent the DP tunner is..keep in mind that hyperpac was around 800
i go on crack list once a day or so to look for stuff. ill keep you in mind brotha
Old Oct 5, 2010 | 12:07 AM
  #37
big poppa's Avatar
big poppa
Good deal Philip, let me know, I'll be around. Bryce, forget about the Superchips too, it worked for me at the time but its nothing compared to custom.
Old Oct 5, 2010 | 08:44 AM
  #38
Spool&Go's Avatar
Spool&Go
Ya ya I know. I am more of a sprinter. ha. But I want to do it right the first time. I just get jacked up about it and it sometimes bites me in the butt having to do things twice. I'll just do the gauges for now and if money permits when I get my tax return then I will tune it up.
Ya it is a good deal but I actually found some brand new for only a little bit more so maybe I will go with that just to make sure that I have everything to install the gauges correctly. Still waiting on the pics from the guy.
Sweet! Thanks broski. I appreciate it.
Ya, a chip that i would use temporarily would only make it longer that I have to wait to get it done right. Thanks
Old Oct 5, 2010 | 08:54 AM
  #39
Spool&Go's Avatar
Spool&Go
See. I told you that I am anxious to get something. I say that I am going to wait but yesterday before I decided that, I had emailed and pm'd people about items. Is this too good of a price to pass up?
$150
QUOTE: As far as I know it will. It's the standard Xcalibrator 2 that works on any Ford with an OBD-II port. The model # is 9400. Check with your tuner to confirm though.
_________
Old Oct 5, 2010 | 11:06 AM
  #40
cj45lc's Avatar
cj45lc
$150
_________
Here you go again haha. IDK about that but you coolant strips will be to you by Fri. BTW found the Cat ELC for 15.40 gal, better $ than I hoped for Good Luck Bud
Old Oct 5, 2010 | 11:11 AM
  #41
Spool&Go's Avatar
Spool&Go
haha. Ya I know. And thanks for mailing those bud. I appreciate it.
Old Oct 5, 2010 | 11:15 AM
  #42
cj45lc's Avatar
cj45lc
Your welcome, sorry the #'s didn't work out on the banks chip
Old Oct 5, 2010 | 11:30 AM
  #43
Spool&Go's Avatar
Spool&Go
Its all good. Its not the end of the world. You were the one to give me a wild hair to get a chip/tuner asap though haha. Just got a call from a guy with superchips. He wanted 120 bucks for it and couldn't set it to stock so it would cost me another $100 to make it work. I told him NO WAY! Aren't you proud?
Old Oct 5, 2010 | 11:32 AM
  #44
cj45lc's Avatar
cj45lc
ATTA BOY!! IDK but seems like your trying to blame something on the old guy ( wild hair )
Old Oct 5, 2010 | 12:29 PM
  #45
Spool&Go's Avatar
Spool&Go
Haha. I cant blame the PMS on anybody but myself any more. I'm past that denial stage
