Need some input for my bad memory.
Old Oct 3, 2010 | 06:39 PM
F250_'s Avatar
F250_
I finally got around to the intanks on my 2003 Excursion. Everything went smooth, but I got a HUGE surprise when I went to cut the fill and vent tubes. The vent tube was only protruding into the tank about 2-1/2 inches instead of the 6 inches I found in my F250's setup!!
Still, but cutting as much as I could (only about 1"), the tank filled up much better adn much quicker.... until I noticed diesel pouring out from under the truck!!!!
Now I need to drop the tank again and find out if I damaged the fill line while re-installing, but I suspect I just didn;t get the screw-on ring back on tight enough.
Anyway... here are my questions.
I did not discover rubber hose on the quick connect flex lines... they were hard flex poly lines which are molded onto the hard tubing. I don;t remember seeing that when I did the intanks and pre-pump mods on my truck several years ago.
1. Sooo.... do I just shave off the poly lines while beign careful to not damage the hard line with the blade?
2. Also... the quick connect was so doggone close to the inlet on the fuel pump that my fuel line tool doesn't fit in to remove the quick connect. How do I take care of that one?
Thanks guys!
Old Oct 3, 2010 | 07:41 PM
tdpower's Avatar
tdpower
Did you look on Guzzle's site at the write up? When I did mine I ran a new hose from the tank to pump. Did you put an inline filter on?
Old Oct 3, 2010 | 07:53 PM
F350-6's Avatar
F350-6
1. Yes, just shave it off.
2. See #1. Those disconnect tools either work great, or are a PITA. If you're getting rid of the quick connect at the fuel pump, either cut the fitting off, or yank out the plastic U shaped clip that helps hole the line in place.
Old Oct 3, 2010 | 08:02 PM
F250_'s Avatar
F250_
Grant:
Yes, I've looked at Guzzle's site frequently. Regarding the inline filter.... not in yet because I was holding off until I replaced the plastic tubing with fuel hose. My tank was clean, so I'm just taking my chances on this load of fuel until I can get it low enough to transfer into containers. My personal preference is to leave the existing hard line in place and only replace the flex portions with the new hose.
Chris... thanks for the confirmation. The tools work great where there is plenty of room to get it into position, but that's not the case at the entrance to the pump... just too closely coupled. Given our normal mileage per month, it will take nearly a month ofr me to get back to this again, but I will certainliy do it because I have to find/fix the leaking situation and also get that filter in line.
Thanks guys.
Old Oct 3, 2010 | 08:09 PM
PaysonPSD's Avatar
PaysonPSD
Pete,
The fitting in the fuel pump can be taken out. It will turn inside the quick-connect and unscrew from the pump.
Then maybe you can get the quick-connect disconnected. Then you can just put the fitting back in the pump.
Old Oct 3, 2010 | 08:12 PM
F250_'s Avatar
F250_
I did not know that, Robin. Thanks.
Old Oct 3, 2010 | 08:23 PM
PaysonPSD's Avatar
PaysonPSD
Found out when replacing my pump. Hope it helps getting the quick-connect loose.
Old Oct 3, 2010 | 09:20 PM
tdpower's Avatar
tdpower
I would consider installing a shut off valve as well. You can find the grainger part number in this thread:
https://www.ford-trucks.com/forums/9...filters-2.html
Old Oct 3, 2010 | 10:13 PM
DieselCamper01's Avatar
DieselCamper01
Not sure which disconnect tool you are using Pete but I had to buy a cheap plastic one to fit in some tight spots when I replaced the intake on our Llumina. I thought no way in heck that thing would work but I could really muscle it into the tight spots without it breaking. Picked it up at Napa for under $5 I think. I could not use the nice metal ones I bought for doing the truck intank mods
Old Oct 3, 2010 | 10:33 PM
F250_'s Avatar
F250_
I appreciate the suggestion, and might would have done that a few years ago, but I've found that a c-clamp on either side of the filter connection works perfectly (I use two short blocks of wood to prevent damaging the hose).
The older I get the cheaper I get (which is also affected by having just spent a year living on my savings with not enough income to cover living expenses).
