Need Some Header Advice
This is my first trip into the Classic Ford Truck world and am loving the forums here!I have done some searching on the for the answer to the header question and have seen a variety of responses...
It's got rebuilt 390 going in this week (the 360 was shot, so I figured as long as I was rebuilding, why not go a little bigger). It has the option of the secondary tank on the driver's side, though its not installed at this time. The existing stock manifold is leaking and is in pretty bad shape, so I have been pondering headers.
I looked up Hookers, Hedmans, and Flowtech...spent time on the Summit site, Jegs and a few others and they all seem to have options. I am not opposed to those selections, however, with all the starter issues people are posting and all the trouble getting them to fit, I'm a bit hesitant to jump in...Is there really a good option for this truck? I am planning on getting the extra tank back in there shortly & I'll be installing the headers on my own and taking it to a shop for the rest.
Any body happy with what they've got? Any help figuring out the least problematic option would be fantastic.
...And I am prepared to go higher $$ over potential problems...
It's got rebuilt 390 going in this week (the 360 was shot, so I figured as long as I was rebuilding, why not go a little bigger). It has the option of the secondary tank on the driver's side, though its not installed at this time. The existing stock manifold is leaking and is in pretty bad, so I have been pondering headers.
I looked up Hookers, Hedmans, and Flowmax...spent time on the Summit site, Jegs and a few others and they all seem to have options. However, with all the starter issues people are posting and all the trouble getting them to fit, is there really a good option for this truck? I am planning on getting the extra tank back in there shortly & I'll be installing the headers on my own and taking it to a shop for the rest.
With a 4wd you may need to look at shorties. You may want to add you gas tank and hitch (if you are using one) before installing the exhaust.
John
As far as the starter goes, my truck has no issues, there is plenty of clearance to install and/or remove the starter....just takes a little twist action to get it in position.
I hadn't considered the fenderwell style. Did you have any problems once you got them installed? With the shorties is there enough clearance over all?
