Gpr problem
Old Oct 2, 2010 | 10:41 PM
robs01f250's Avatar
robs01f250
Gpr problem
On my truck I am having trouble starting in the morning around 40 degrees. I am getting the romps and ALOT of white smoke. I tested the gpr today and have battery voltage on the always hot post. But when I turn the key on I get no power to the other large post. I figured this out because I did the gpr led mod today. I am assuming that I should just go ahead and upgrade to the stancor beefed up gpr. Is this all that needs replacing.
Old Oct 2, 2010 | 10:42 PM
robs01f250's Avatar
robs01f250
I also tested the other hot post with an ohm meter and got zero voltage
Old Oct 2, 2010 | 10:49 PM
fordpride's Avatar
fordpride
you may want to ohm out the GP's to see if you have any bad one will your at it
Old Oct 2, 2010 | 11:10 PM
robles4242's Avatar
robles4242
Agree. I changed my GPR about a few weeks ago. Busy weekend this weekend (i got pics and write ups to post tomorrow) but I too am going to ohm the GPs so i can change any if needed. VERY Easy job. If you use anything other then Stancor DO NOT crank down on the big pots very tight. They will RIP right out! (Prob that you will find caused yours to fail, I did)
Old Oct 2, 2010 | 11:20 PM
fordpride's Avatar
fordpride
if you have to change any GP's only Motorcraft ZD11 you'll thank me if you ever have to change them again
Old Oct 2, 2010 | 11:29 PM
tdpower's Avatar
tdpower
mybigredford
Nov 4, 2014 09:01 PM
jeffsk7
24
Oct 30, 2013 01:04 PM
mojoman
23
May 7, 2010 09:41 AM
2cylguy
Apr 20, 2009 07:17 AM
PSNut
21
Feb 1, 2007 12:23 AM
