No fuel in upper filter???
Old Oct 2, 2010 | 02:20 PM
dchamberlain's Avatar
dchamberlain
Can you hear the pump running?
Old Oct 2, 2010 | 02:25 PM
sswebber's Avatar
sswebber
Yes runs for 15 secs or so I also unplugged it just to see if that was the pump and itwas ..
Old Oct 2, 2010 | 02:28 PM
dchamberlain
That's very odd. I hate to say you may have a failed fuel pump.
If you remove the upper fuel filter and put the key to run, does the upper fuel bowl fill at all?
Old Oct 2, 2010 | 02:29 PM
sswebber's Avatar
sswebber
No it doesnt fill at all
Old Oct 2, 2010 | 02:34 PM
gearloose1's Avatar
gearloose1
There is a risk to doing this.
Unhook the fuel lines from the pump.
See if you see fuel being pumped out.
If yes, measure pressure at that point.
If over 50psi
Then, you got a blocked fuel line.
Old Oct 2, 2010 | 02:37 PM
dchamberlain
The only two things I can figure are the pump has failed, or something internal to the HFCM. Or there is something completely blocking the pickup tube in the fuel tank. It just seems odd that it started right at the same time you changed filters.
You may want to wait and see if anyone else has any suggestions before you go about changing parts out, however.
You could try what gearloose just suggested above also. You'll need a fuel line disconnect tool, and probably an assistant. Be very careful, the pump could pump out a large amount of fuel very quickly.
Old Oct 2, 2010 | 02:40 PM
sswebber's Avatar
sswebber
Ok thanks for the help guys as soon as i get a fuel line tool ill try this
Old Oct 2, 2010 | 02:47 PM
gearloose1's Avatar
gearloose1
Be very careful ---- after you disconnect the fuel line, if the determination is that it is blocked between the fuel pump and the small filter at the engine...
I would disconnect at engine, and try using compress air UP TO 70 psi from the engine end (reverse pressure) to try to blow it out.
If that failed --- you are into replacing the line.
BTW --- check for an obvious block like a kink / damage in the line.
If there is no fuel coming out of pump --- then it is fuel pump, fuel pickup..
Remove the HFCM... blow low pressure (5psi) air into the fuel line and see if you can hear the air bubble through the fuel tank.
Straightforward diagnostics.. not rocket science.
Good luck.
Old Oct 2, 2010 | 03:58 PM
69cj's Avatar
69cj
If you havn't done it the 1st thing I would check is the lower filter O ring. Check for damage and then lube it with oil or vaseline which is what I use. Diesel fuel can swell the O ring and cause it to bind. You could be sucking air from the hfcm. The cap should bottom out before reaching the torque value. If not that is where your problem is. Remember, the O ring seals, not the threads.
Old Oct 2, 2010 | 04:09 PM
gearloose1's Avatar
gearloose1
The nice thing with the Vertical Fuel Conditioning Module is the O-rings is a lot less critical.
Old Nov 3, 2010 | 12:56 PM
stupidjet's Avatar
stupidjet
what was the outcome ssweber?
Old Nov 3, 2010 | 06:09 PM
chromedom's Avatar
chromedom
Veteran: Navy
I would like to know also. Replaced my filters yesterday and had the same problem. Had to cycle my ignition about 12 times to get the bowl to fill and get 50 psi on the fuel pressure. After that it was fine.
Bohen
6.7L Power Stroke Diesel
Feb 24, 2017 03:18 PM
big315
May 13, 2016 01:08 PM
smokersteve
2009 - 2014 F150
Feb 24, 2013 02:23 PM
Scratcher
Jun 8, 2010 09:50 AM
tmh1331
Jan 9, 2009 11:24 PM
