Engine Ticks
Old May 7, 2001 | 12:10 PM
shawn1223's Avatar
shawn1223
Engine Ticks
I have a 1997 4.6 Expedition. The engine ticks constantly, and the ticking seems to speed up w/ acceleration. Sometimes it shifts hard also.
Does anyone have any adivce?
Thanks.
Old May 9, 2001 | 07:24 PM
thermo's Avatar
thermo
Veteran: Navy
Engine Ticks
It sounds like you have 2 separate problems. 1 with the lifters ticking (assumption) and then a shifting problem with the tranny.
For the ticking sound, start the motor and open the hood. See if you can narrow the ticking down to a particular portion of the motor. Crawling under the truck is pretty easy since it sits so high. JUST DON'T STICK YOU FINGERS NEAR THE PULLEYS!!! I know that sounds silly, but look at the number of mechanics with 9 fingers. Odds are, you are going to find the ticking either on the top of the motor at the valve covers or on the front of the engine with the pulleys. If it is with the lifters (top of motor), I would recommend getting some lifter cleaner and follow its directions very close (some are for 15 minutes prior to an oil change, some are for 3,000 miles). I have had good luck getting motors to perform smoother/better after a single treatment. If it is coming from the front of the motor, first check the serpentine belt for signs of aging/cracking/abuse from something hitting it. Then, with the motor off, run your hands around each of the pulleys and see if there is something in close proximity of a pulley and then remove that item.
Odds are, you will find it is a noisy lifter and the cleaner will fix the problem.
For the tranny, when was the last time the tranny fluid was changed? If within 30,000 miles, should still be good. Is the tranny fluid still bright red? If it is turning brown/dark, you may want to look at changing the fluid. If you have 2 different people that drive the vehicle about the same amount of time, you may want to disconnect the battery from the vehicle for a few minutes and let the computer reset itself and see if that corrects the problem before getting the fluid changed. I say that only because the truck tries to learn you driving style and will shift the truck accordingly. With 2 (or more) people driving a vehicle, it can get "confused".
I hope this helps.
Chris "Thermo" Coleman
Old May 14, 2001 | 07:18 AM
shawn1223's Avatar
shawn1223
Engine Ticks
Thanks for your help.
Old May 29, 2001 | 09:30 PM
ed foster's Avatar
ed foster
Engine Ticks
If it's not a loud tick, it's probably just the fuel injectors cycling. They are actually just solenoids cycling on and off.
Old May 30, 2001 | 09:04 PM
philrobj's Avatar
philrobj
Engine Ticks
emgee
15
Feb 7, 2015 10:47 AM
seebeew
Paint & Bodywork
Apr 8, 2005 09:44 PM
dhashberger
Aug 30, 2004 01:57 PM
seebeew
Exhaust Systems
Sep 5, 2001 03:36 AM
seebeew
Jul 19, 2001 11:51 PM
