Sponsored by: Real Truck
hub seal ?
Old Oct 1, 2010 | 05:55 PM
joeycyph56's Avatar
joeycyph56
hub seal ?
i feel a little silly right now. i just bought the esof reseal kit (from ed of course, thanks)and im looking at all the seals that came with it and am feeling a little intimadated by it. i understand about the first seal on the 4x4 but am lost on the rest due to me never having it apart. i am currently not experiencing problems but my driver side dial has frozen in place which tells me dirt is gettin through and i do have 40k miles and it being an 06 i figure its time to grease it all up.if any one has some direction for me i would appreciate it. thanks also what type of graese would you recomend to regrease , i have castrol perplex red wheel bearing grease. i am not sure if its right for this application
Old Oct 4, 2010 | 11:19 AM
joeycyph56's Avatar
joeycyph56
has anyone taking apart the front hubs on a 05 up that has pics?..
Old Oct 4, 2010 | 03:41 PM
ak-angler's Avatar
ak-angler
This is for a 2002, but it may help.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Oct 4, 2010 | 04:36 PM
EXv10's Avatar
EXv10
Your seals
The big expensive looking seal is your knuckle seal, the yellow o-ring goes around the outside of the hub where it slides in, the black one goes on the locking hub and they probably gave you 2 of those. Take the locking hub apart and turn the dial all the way to the left plus 1/4" and it should come out so you can replace that seal with a generic one. You might have to soak the dial in penetrating oil overnight after you drill a hole in it to let the oil into it.
Old Oct 4, 2010 | 05:53 PM
06Superduty's Avatar
06Superduty
Here is a thread that may help you.
https://www.ford-trucks.com/forums/9...with-pics.html
MarksA-C
Dec 20, 2011 04:37 PM
Firefighter 1406
Jun 10, 2009 08:52 AM
dannyo
Dec 18, 2005 08:05 PM
monsterbaby
May 14, 2005 09:05 PM
96bronco58
1978 - 1996 Big Bronco
Sep 2, 2003 05:39 PM
