Sponsored by: Real Truck
white smoke when acclerating
Old Sep 30, 2010 | 12:32 PM
75Three90's Avatar
75Three90
ok i have a 1999 f250 super duty with a 7.3 power stroke, the glow pulgs and injectors have 12,000 miles on them and the transsmision has 7,000 miles and the rear end has 8,000 miles on it all work has been done by a Ford Dealership and now im getting big puffs of white some under accleration what would cause this?
Old Sep 30, 2010 | 12:39 PM
gearloose1's Avatar
gearloose1
Lots of things, incomplete combustion? (if diesel), coolant (if something broke like head gaskets blown), oil (blown rings)?
What does it smell like?
Old Sep 30, 2010 | 12:49 PM
75Three90's Avatar
75Three90
it smells like raw fuel, i heard somthing bout a high pressure oil pump on the front of the motor that may cause it
Old Sep 30, 2010 | 01:11 PM
gearloose1's Avatar
gearloose1
I would take it back to the dealer that got all that $$$ for the past work.
Sounds like overfueling condition...
Old Oct 3, 2010 | 03:21 PM
75Three90's Avatar
75Three90
thats what i was thinking
Old Oct 3, 2010 | 07:52 PM
Shaggy76's Avatar
Shaggy76
White Smoke = Too much fuel
Black smoke = Not enough Air
This is based on wether or not your ratios are correct. There are a lot of other things it could be, but this is the basics when it comes to diesel engines.
1 thing these 7.3's are famous for is blowing tips on fuel injectors. What happens is you get a drop of water in your fuel line and the holes are really small in your injectors. The water will settle in the tip of the injector, but can't get blown out because the holes are too small for the drop of water to go through. Then what happens is the injector gets abnormally hot from the combustion stroke (fuel cools the injectors and water prevents the tips from cooling). When it get's it's hottest (approx 15 degrees before TDC) just before the fuel spray (5 degrees before TDC), the whole tip of the injector blows off as the water steams up and trys to escape with high pressure just as the fuel pressure trys to spray the fuel. You then have a fuel pour issue instead of the normal fuel spray. In other words, instead of 5-7 tiny small holes, it turns into 1 bigger hole.
Your engine will still run, just produce white smoke only during acceleration, and will produce a strong fuel smell with no pinging (diesel knock). Most call it just a plain bad injector and replace the injectors, but will not do a bleed off to make sure no water is still in the line.
Just something to look at as well as all the other usual stuff...
Blown rings are no the cause for 1 of 2 things happen. Coolant will get in combustion and produce white smoke, but strong fuel smell will not be present. Oil will get in combustion and produce black smoke, but no strong fuel smell. Both of these will cause a ping (diesel knock) condition. Plus oil pressures will be lower than normal.
Incomplete combustion will kick off codes (due to OX sensor in one of the 2 banks reading high Nox) and produce a ping.
High pressure oil pump could cause the o-rings in the injector to unseat, but will not cause the fuel smell.
I hope this answers some questions for you and helps you in determining your issue. I answered this way to assist others that answered as well to come up with a conclusion to the problem.
Last edited by Shaggy76; Oct 3, 2010 at 08:07 PM. Reason: Added answers to other posts.
Old Oct 3, 2010 | 11:19 PM
Lubbockguy1979's Avatar
Lubbockguy1979
mine sometimes has white smoke during acceleration.... generally when my wifes not in the truck think it is due to lack of traction though
Old Oct 4, 2010 | 05:57 PM
cliles55's Avatar
cliles55
I don't know if this link will help you but it has some good info; click here.
The '84 6.9 I had allowed me to time the injection pump; can't help you on the 7.3.
Hope this helps,
