#2 Injector
Old Oct 1, 2010 | 12:45 PM
polar888's Avatar
polar888
#2 Injector
I replaced the #2 injector twice. This time, it only lasted 3 days before acting up. My scanner just says #2 misfire. Is there anything upstream that would cause chronic problems for a single cylinder?
I'm switching plugs, coil, and injector with #1 right now and going to see if it is a parts problem or something isolated to #2.
Any stories of frustration with a happy ending would be most appreciated so I can narrow this thing down.
Old Oct 1, 2010 | 05:52 PM
svt2205's Avatar
svt2205
Only change one part at a time, like the coil or the injector. If you do all at once, you wont know which part is the problem. That's assuming the problem follows the moved part.
Old Oct 1, 2010 | 07:25 PM
Still Smoking's Avatar
Still Smoking
Im in the same boat as you. Except I got a number 7 misfire. 2 weeks ago they changed the fuel injector on that side and now its acting up again. They are changing the cam phaser now to see if thats it. Should have had the truck back today but waiting on a gasket.
Old Oct 1, 2010 | 07:56 PM
70f100longbed's Avatar
70f100longbed
A cam phaser wont cause a misfire on one cylinder. Make sure the connectors for the coil and injectors are fully locked in place. Then you can switch the coil with another cylinder to see if the misfire moves. If it doesn't, most likely the plug is bad.
Old Oct 1, 2010 | 09:16 PM
Wilber15's Avatar
Wilber15
Coil pack...........
Xenthrax
21
May 16, 2013 02:41 PM
JT250
Sep 11, 2012 01:42 PM
catman52987
Jan 29, 2012 10:37 PM
2dave2
Aug 15, 2001 04:23 AM
