grinding noise?
Old Oct 1, 2010 | 10:31 AM
pittmick's Avatar
pittmick
grinding noise?
Noticed yesterday that there is a ginding noise comming from the wheel hub that I hear as the wheel turns in tempo with the wheel turning. I need to replace the wheel cylinders as they are leaking. Wheel bearings were packed recently. Could it be the brake shoes?
Old Oct 1, 2010 | 11:22 AM
big78f150's Avatar
big78f150
my truck is doing the same thing on the driver side
Old Oct 1, 2010 | 12:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Front or rear? Regardless, you need to pull the wheel and check. Don't take any chances.
Old Oct 1, 2010 | 01:56 PM
pittmick's Avatar
pittmick
Pretty sure its the rear. I'm just wondering if the leaking wheel cylinders could cause this? As the wheel turns the grinding noise happens. In other words its off for a spit second and on for a spit second speeding up or down to the speed of the truck.
Old Oct 1, 2010 | 02:16 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Don't see how a leaking wheel cylinder would cause this. You need to pull the wheel and see whats going on. It could be worn brake shoes but don't take any chances. Tear it down and see whats causing it and fix it.
Old Oct 11, 2010 | 02:51 PM
big78f150's Avatar
big78f150
did you ever fix this? mine started making a knocking sound on my way back from the river the other night
Old Oct 11, 2010 | 07:01 PM
Big_Dom's Avatar
Big_Dom
wheel bearing....
Old Oct 11, 2010 | 07:11 PM
arctic y block's Avatar
arctic y block
The PO prolly died when his wheel bearing let lose and can't answer. Shoulda tore it down
Old Oct 11, 2010 | 07:33 PM
big78f150's Avatar
big78f150
i figured it was just aint felt like messin with it.
Old Oct 12, 2010 | 01:52 AM
pittmick's Avatar
pittmick
Sorry I havent been on the site for awhile. Yeah I jacked the truck up and manually spun each rear wheel forward and backward and didnt hear anything at all. Put it back down on the ground and drove it only to find the grinding noise was totally gone. Really dont know what happened, but probably had something hung up in the hub?
Old Oct 12, 2010 | 08:57 AM
bkaul's Avatar
bkaul
Could've had a little rock stuck against the brake drum that fell out when you jacked it up, or something along those lines.
resq302
Aug 21, 2018 10:29 AM
palbertsen
2004 - 2008 F150
May 28, 2015 03:29 PM
dougcepress
Dec 7, 2014 08:16 AM
Suprawill1
Escape & Escape Hybrid
Oct 14, 2014 12:57 PM
posthumus86
1997 - 2003 F150
Jun 13, 2013 06:14 AM
