wipers stopped working tonight...
Old Jun 18, 2019 | 04:59 AM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by bigb56
it can only be a grounding issue.
To add to what bigb56 said, check the ground that is bolted to the firewall above the hydroboost. Mine broke and caused problems with wipers. It even made the truck quit whenever I turned the ESOF switch.
Old Jun 28, 2020 | 08:53 PM
zeppelindad's Avatar
zeppelindad
Wiper and washer issue fixed!
I know this is an old thread but hoping this helps others. This is what I found on a 2003 Ford super duty to fix my issue after replacing the wiper
motor and turn signal stalk didn’t fix it. Note that both the wiper motor and windshield cleaner stopped at same time.
i found the green high current 12v wire had an open wore through where the wire met the sharp edge of the fender well. There are 4 large connectors on fender well that interconnect the wires from in the cab to the other parts of the truck. The one furthest towards the front of the truck is the one where the green power wire for wiper motor is plugged.
I ran a new wire between the open and moved this connector off of the fender well so this wouldn’t happen again.
Old Dec 29, 2020 | 03:50 PM
DJ_Dave's Avatar
DJ_Dave
exact same thing happened to my 2004 f250 gasser thanks for the post
Old Dec 29, 2020 | 05:25 PM
zeppelindad
I posted it in case it helped someone else so glad it did help you.
That’s the beauty of these forums , they’ve helped me so much .
cheers
lisahall
Apr 29, 2017 06:56 PM
svastano
Apr 27, 2017 09:12 PM
Harry Kage
Apr 15, 2017 11:33 AM
judogold
Sep 10, 2016 12:23 PM
xclint
1997 - 2003 F150
Jul 23, 2007 11:23 AM
