TURN SIGNAL PROBLEM
Old Sep 30, 2010 | 09:21 PM
sierra308's Avatar
sierra308
Question TURN SIGNAL PROBLEM
I have a 67 F-100.The problem is when you turn on either blinker the brake light goes out instead of flashing.I have replaced the turn signal flasher,and the emergency flasher.The emergency flashers do work.Any help will be appreciated.I have been reading schematics and tracing wires for four days.Thanks
Old Sep 30, 2010 | 09:40 PM
toolman247's Avatar
toolman247
After being through this with while towing trailers out of state this sounds like your turn signal switch has given up in this life.
Old Oct 1, 2010 | 03:27 AM
jowilker's Avatar
jowilker
308 FYI, The brakes & flasher share the same wire from the front & bulb filament. So when brakes are applied the t signal is actually turning the light off making it blink.
Hope I didn't fuse you.
John
hdunlap
16
Nov 19, 2016 02:36 PM
Gramps67highboy
Jan 27, 2015 06:54 PM
E30tdf
Electrical Systems/Wiring
May 17, 2014 12:55 AM
dakonthemountain
13
Nov 26, 2005 10:13 AM
jjltraveler
Mar 3, 2004 06:39 PM
