1993 E350 7.5 L - Flashers
No turn signals but emergency flashers work.
Is there a 2nd Flasher for the turn signals? Or does the emergency flasher also serve the signals?
Thanks for the help!
PS: I see from the Rockauto catalog that this design may have a flasher and relay built into the turn signal switch. Comments?
Turn signals working again!
Turned out to be corrosion on the turn signal switch terminals! ( i.e. electrical power loss due to corrosion)
I had checked related fuses before I posted.
Thanks for your replies gents!
NOTE: That's not the end of the story though. 70 miles out on a trip down to Cannon Beach, OR, a fire erupted under the dog house. Fortunately, I put the fire out with my fire extinguisher. Turns out pesky rodents has built a sizable nest on top the back of my engine (out of site unless you popped the dog house).
The MH was towed back to my house with some wiring and vacuum line damage as well as damage to the dog house and maybe more. Lucky I did't witness THE THING BURN TO THE GROUND. Scary moments!
cdat81986
18
09-14-2022 08:02 AM
