6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fuel/Water Separator
Old Sep 30, 2010 | 07:20 PM
KC8QVO's Avatar
KC8QVO
I let mine drain for around a minute and didn't see much change in the fluid. Truck has 3500 miles, first time I've drained it so I am not sure if I was doing it right. The light didn't come on but its been over a month and I hear draining it once a month is best.
Old Sep 30, 2010 | 07:39 PM
Bounds-Electric's Avatar
Bounds-Electric
FORD USER
Sounds good, you may or may not see water, you can put in clean container and let sit over night to see if you have water! Cut off, turn key on, let sit , than start!
Old Sep 30, 2010 | 07:58 PM
senix's Avatar
senix
That is just the way it is hopefully suppose to be. No water. Still adviseable to drain monthly.
When I was driving diesels in the Army, I drained daily..good preventive maintance.
Old Sep 30, 2010 | 09:31 PM
Bounds-Electric
FORD USER
The problem is you will never know when your going to get water, better to drain with no water than not drain at all. No harm to drain any time. This will also keep drain from sticking!
Old Oct 1, 2010 | 09:47 AM
kjstanger's Avatar
kjstanger
Being that I am new to diesel's, I thought I read somewhere on this forum that the truck actually monitors this and will display messege that states it has to be drained. I'll still do it on a monthly basis as mentioned, just wanted to get a verification if the truck monitors this.
Old Oct 1, 2010 | 09:57 AM
senix's Avatar
senix
there is a sensor in the fuel/water separator that will display a warning on the dash, but I would rather not depend upon that as it may be too late when it comes on.
Old Oct 1, 2010 | 10:01 AM
kjstanger's Avatar
kjstanger
Thanks senix, I'll do my best to do it every month for good practice.
Old May 17, 2011 | 10:52 PM
JBFelsing's Avatar
JBFelsing
Is it unusual to have the lever on the water separator be hard to move? I don't want to force it and break it off.
Old May 18, 2011 | 05:04 AM
senix's Avatar
senix
that is a tell tale sign that you need to take that cover off, clean it all up inside. Full of crud. Don't delay.
Old May 18, 2011 | 06:31 AM
Gearitis's Avatar
Gearitis
There are 3 bolts around the yellow lever, that uses a Star socket, I forgot the size, I want to say T-20, anyway, take that apart and it will allow you to cleanup only the ball valve and all the trash in there. I was having issues with "not draining". Well, took the 3 minutes to take the valve off and holy moly, there was green, blue, purple stuff, dirt and slime and other things that I had no idea what it was all in and around the valve and into the filter area. Any way, once I got that cleaned out and up, reassembled and everything worked like a charm. I did it with my old filter in as I was getting ready to change. I did get a little bit of a diesel bath but not bad.
Old May 18, 2011 | 08:59 AM
Mud Doc's Avatar
Mud Doc
Gearitis,
That all there is to it? There is no gasket between the main housing and the valve housing? I have to replace mine--got it in hand, and wondering how to go about it.
Thanks for the above description.
Joe
Old May 18, 2011 | 06:21 PM
Gearitis's Avatar
Gearitis
Originally Posted by Mud Doc
Gearitis,
Joe
I had no gasket. It is machined pretty tight. When I put it back on, I torqued it snugg but did not crank on it since its aluminum. Just make sure its clean, I wiped it down and out with a microfibre rag. Should be good to go.
Old May 18, 2011 | 07:11 PM
sportsfreaked's Avatar
sportsfreaked
Gearitis,
Joe
If you take all 5 screws out and take the cover off you will need a new gasket. They swell after you put them in and the old gasket will not fit properly. Trust me I learned the hard way . No one here stocked the gasket and it took a day or two to get in.
Old May 18, 2011 | 07:53 PM
bnmccoy's Avatar
bnmccoy
FYI
44 lb-in on the drain valve cover or the manifold cover bolts per the service manual.
Old May 18, 2011 | 10:06 PM
JBFelsing's Avatar
JBFelsing
Thanks to all who replied. I will take care of this over the weekend. I sure wish I would have done this when I changed the filter a month ago when I purchased the truck. 2008 CC Lariat 4x4. Already had the radiator & thermostats replaced under warranty. I keep a close eye on things as I'am here reading every day so I was aware of what to look for with these trucks. Still have 25,000 to go before 5yr/100K is up so the more Ford pays for the better. I keep it on the highway 95% of the time so I will be hoping for the best. I'am contemplating DPF delete when warranty is up though.
DPDISXR4Ti
Nov 16, 2015 08:23 PM
bleeds blue
Nov 24, 2014 03:08 PM
Restlesswildman
Feb 21, 2014 09:55 PM
redman84
16
Sep 5, 2012 12:03 PM
rmilchman
May 17, 2006 08:56 AM
