Upper intake bolt?
Old Sep 30, 2010 | 04:49 PM
Zorfox's Avatar
Zorfox
Upper intake bolt?
Need to remove the upper intake manifold (plenum) from my 1992 F150 5.0. One of the center bolts on the passenger side is a torx head. It appears to be about a T40 but not sure. All I have are 3/8" sockets which are to fat to fit into the manifold housing. I called the parts store, only one here, and they only have the same as me. An 8" torx srewdriver may reach but doubtful if it would hold up to the torque required. What do you use for this? Do I need to find a 3/8" drive socket with a slimmer profile or is this one of those tools nobody has. Wouldn't you know it, one bolt holding the whole job up .
Old Sep 30, 2010 | 06:12 PM
timbersteel's Avatar
timbersteel
Been there, it sux! I went and bought a cheap torx set, the long ones from the $5 and $9 bins at like ACE and other places. I then bought a 6", 1/4 extension and used my 1/4 to 3/8 socket adapter and it took some wrangling to get it out! I had to grind the end every so often cause it twisting it.
Old Sep 30, 2010 | 06:27 PM
old_lynrd's Avatar
old_lynrd
i know its money...but snap-on sells a extended torx socket just for this job...no idea how much but its good to have...
DBGrif91's Avatar
DBGrif91
I have a torx bit set w/ a 1/4" drive adapter. Works just fine.
Old Sep 30, 2010 | 07:43 PM
Zorfox's Avatar
Zorfox
Thanks for the advice. I ended up at one of my neighbors houses bumming tools lol. We made up an extension with a few 1/4" extensions a 6mm socket and a drill bit torx bit. It looked funky but it worked! When you live in the middle of nowhere you do what ya gotta do.
I ran out of light tonight. I dropped my oil pan but it looks like I am going to have to REMOVE the exhaust! The cross pipe blocks the pan from dropping down in the rear. Funny the manual says it's not necessary, any tricks or am I missing the obvious (which wouldn't be the first time).
Did I just hijack my own thread? LOL
Old Sep 30, 2010 | 09:49 PM
timbersteel
Gotta drop the y-pipe...Same here for me. It was a pain. Had to cut the bolts to get it down.
guzzler96
19
Sep 28, 2025 07:57 PM
c3racer2000
1978 - 1996 Big Bronco
Mar 7, 2022 04:32 AM
2.5itim
Sep 20, 2016 07:52 PM
Toored
Nov 2, 2012 08:01 AM
midlf
Aug 15, 2008 02:20 PM
